Need help with partitions in Windows XP - LS1TECH
Thread Tools Search this Thread
Old 08-18-2007, 12:48 AM   #1
RyRy's Avatar
Default Need help with partitions in Windows XP
Ive searched all over the windows help file and cant find what I need so Im turning to you guys hoping someone may be able to help.
So heres the situation:
So when my parents got their computer it was partitioned into a C: and a D: with a windows installed to the C:. the partitions have the following memory allocation:
C: has ~15GB
D: has ~105GB
Now as theyve been using it the C drive has filled up but the D drive is empty. I know the easy thing here would be to have them start saving things and moving files over to the D drive. They're not too literate when it comes to computers and this may be a problem. So what I want to do is either extend the C drive to take up a majority of the hard drive size (ie extend it to about 100GB or so) or delete the D: and extend the C:.
I basically want to make it as easy as possible for them and diskpart in DOS wouldnt work to do either of the above options. Can anyone help me out??? Please???
Thanks guys!
RyRy is offline   Reply With Quote
Old 08-18-2007, 01:46 AM   #2
I have never done it but I Partition Magic or Acronis Disk something or other could probably do it for you.
See if you can shrink (or delete, if nothing is on it) the D drive and then add it to C.
aliensRreal is offline   Reply With Quote
Old 08-18-2007, 01:55 AM   #3
RyRy's Avatar
Ive looked into Partition Magic but I was hoping theres a trick that wouldnt cost $70.
Apparently theres some files that cannot be deleted residing on the D partition which kinda throws a wrench into the works...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
