Best way to kill a car battery? - LS1TECH
Thread Tools Search this Thread
Old 03-21-2008, 05:45 PM   #1
Hank Hill's Avatar
Location: Grammar Nazi Regional Headquarters; Arlen, Texas, U S of A
Default Best way to kill a car battery?
The battery on my '99 just barely made it through the winter. I think it's about 5 years old which is way longer than I usually get.
I've tried trickle charging it, but it's still weak, and my voltmeter shows plenty of volts when the car is running so it's nothing wrong with my charging system. I'm just worried it's going to get me stuck some day, if I don't happen to park on a downhill.
I think it's an 84-month warranty on the DieHard (Gold or whatever) that I got. But Sears won't warranty a battery unless it absolutely won't hold a charge; mine holds a charge, just not a particularly strong one -- and it seems to be getting weaker.
I remember a friend years ago would cut up pennies and drop them in the water holes, which supposedly would kill a battery, but I'm not really looking to defraud Sears.
Any ideas on how to kill my battery (without a trace) so i can get it replaced under warranty?
Hank Hill is offline   Reply With Quote
Old 03-21-2008, 05:46 PM   #2
oneBADDz's Avatar
Pull it out and sit it on a concrete floor (garage, driveway) for a week
oneBADDz is offline   Reply With Quote
Old 03-21-2008, 06:25 PM   #3
Hank Hill's Avatar
Quote:
Does that actually work? What about if I still want to drive the car at least every other day in the meantime? Any quicker way to do it?
Old 03-21-2008, 06:27 PM   #4
2002_Z28_Six_Speed's Avatar
Is it sealed or vented? Turn it upside down in a large tupperware container for awhile.
Claim you don't know what happened.
2002_Z28_Six_Speed is offline   Reply With Quote
Old 03-21-2008, 06:43 PM   #5
SpaZMaN's Avatar
Replace the acid/water mix(assuming its vented) with regular water until the battery runs out.
Not sure if it works, but its worth a try.
SpaZMaN is offline   Reply With Quote
Old 03-21-2008, 07:58 PM   #6
CLUBBER LANG's Avatar
just buy a new battery in the meantime, do what these guys suggest and drain it, turn it in, get your money. only problem is you'll be out the money for a new battery for a short time.
CLUBBER LANG is offline   Reply With Quote
Old 03-21-2008, 09:36 PM   #7
98LS-WON's Avatar
Hook it up to very low current draw, like a small light bulb and let it burn for as long as it can. When your battery can't put out .1 amps to keep it lit, then leave it connected for another week. You can bet it has probably blown its wad. I don't know for sure, but I'd expect it not to accept much of a charge after that. Good luck.
98LS-WON is offline   Reply With Quote
Old 03-21-2008, 10:13 PM   #8
BLK85's Avatar
A guy that used to do my job at work tried soldering multiple batteries togeather. They exploded, lol. This was with 3.2 volt batteries.
BLK85 is offline   Reply With Quote
Old 03-21-2008, 10:15 PM   #9
WhosNXT's Avatar
Quote:
I would like to hear that story....what a genius.
WhosNXT is offline   Reply With Quote
Old 03-21-2008, 10:34 PM   #10
BLK85's Avatar
Quote:
I didnt work here at the time so its just from what Ive been told from people that did.
He was bored(pretty common for my job) so he thought about soldering two batteries together. They are 3.2 volt batteries that are in the mother boards of our computers. I guess he tried soldering two together. I dont know if he did it negative to negative or positive to positive or negative to positive. But I guess the result was exploding batteries. All of the internals and externals of the battery went to the ceilleing (probably 12 foot or so) and are still there and all the mariteral went all over this guys glasses. The stuff on the ceileing is still there so I believe the story.
Thats what I heard from the person that did it and people that worked in my department at the time.
Old 03-21-2008, 10:37 PM   #11
WhosNXT's Avatar
Thats funny! I wish I could have seen the look on his face....
Old 03-21-2008, 10:38 PM   #12
BLK85's Avatar
Me too....
Old 03-21-2008, 11:07 PM   #13
lastcall190's Avatar
What a story hahaha... the concrete thing, don't think it works. I had a die hard on the floor in my garage over 2 years (pulled from my old LT1 before I sold it for whatever reason... still not sure). It presently resides in my Formula and it's been rock solid. -J
lastcall190 is offline   Reply With Quote
Old 03-21-2008, 11:35 PM   #14
Tech Resident
ChocoTaco369's Avatar
Shoot it with a 30-30. I bet that'll kill it.
ChocoTaco369 is offline   Reply With Quote
Old 03-21-2008, 11:58 PM   #15
CrabhartLS1's Avatar
hook it up to a 800W amp, killed mine pretty quickly.
I've heard of cement too just put it on your garage floor.
CrabhartLS1 is offline   Reply With Quote
Old 03-22-2008, 12:37 AM   #16
XxGarbSxX's Avatar
And now a suggestion from the bad idea department...
Three words: Twenty. Pound. Sledgehammer.
XxGarbSxX is offline   Reply With Quote
Old 03-22-2008, 01:40 AM   #17
FMX05's Avatar
Find a friend with at least 1000w worth of sound equipment, hook it up, and turn it on accessory. It should be dead in ~3-4 hours. put it on a fairly rapid charge, and repeat. 3 cycles and it should be as worthless as a 305 short block.
FMX05 is offline   Reply With Quote
Old 03-22-2008, 01:43 AM   #18
Revelation Z28's Avatar
throw it in the fireplace if its still cold there.
Revelation Z28 is offline   Reply With Quote
Old 03-22-2008, 01:44 AM   #19
Joshiedoom's Avatar
I had a battery that wouldnt hold a charge for over a day and I took it to get replaced and they charged it and said it was fine and wouldnt replace it.. so I drained the battery and put water in it and took it to another of the same chain store. W00t...
Joshiedoom is offline   Reply With Quote
Old 03-22-2008, 09:54 AM   #20
Tudds's Avatar
get an inverter and plug everything you can into it. Kill it and let it sit... return the inverter
Tudds is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Battery not charging and red battery dash light... Racin96ss Cadillac CTS-V 2004-2007 (Gen I) 18 07-25-2016 08:43 AM
new alternator, now "battery not charging" RADEoN Cadillac CTS-V 2004-2007 (Gen I) 48 10-23-2015 05:05 PM
Battery or Alternator? kjcmusic17 Stereo & Electronics 7 09-12-2014 12:38 PM
Charging System Failure lVloses LS4 Performance 4 12-27-2013 06:46 AM
Car won't start. Security light on. I'll explain... Ghostintheshell Generation III External Engine 15 11-09-2012 12:10 AM
Tags
auto, battery, car, fast, fastest, good, how, kill, posts, quickest, shorting, smaller, warranty, water, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
