How is your FIXED BACK race seat mounted? - LS1TECH
Road Racing Road Course | Autocross
Thread Tools Search this Thread
Old 09-16-2011, 09:00 AM   #1
FASTFATBOY's Avatar
Default How is your FIXED BACK race seat mounted?
I am looking at putting Corbeau FX1's in my car. The wide version on the drivers side.
Pics and info on how your fixed back seat is mounted please.
FASTFATBOY is offline   Reply With Quote
Old 09-16-2011, 09:30 AM   #2
SIK02SS's Avatar
with Cobra brackets on a slider using factory bolt holes, don't have pics. nothing really rocket science about it, I bet something as simple as Arizen brackets/slider would work..
SIK02SS is offline   Reply With Quote
Old 09-16-2011, 10:16 AM   #3
mitchntx's Avatar
Four 1/4-20 grade 8 bolts with heavy fender washers.
Bolts into a section of 1 1/2" square tube with 1/4-20 threaded inserts welded into one side.
Square tubes are welded to the factory seat channels on the floor.
On an aluminum seat, drill through the seat and mount.
With a composite seat, use the 90* angle side mounts.
mitchntx is offline   Reply With Quote
Old 09-16-2011, 11:28 AM   #4
FASTFATBOY's Avatar
If I bought an aluminum seat, I am looking at a Ultrashield Rallysport seat, and Corbeau brackets....can I bolt the seat directly to the bracket with a plate in the bottom of the seat to spread the load?
Or does it need to be mounted with the side plates?
Old 09-16-2011, 12:57 PM   #5
mitchntx's Avatar
I use fender washers to spread the load. No need for a plate.
An aluminum seat will need a back brace braced against a cross bar.
Only FIA rated seats don't require a back brace.
Old 09-16-2011, 01:04 PM   #6
SIK02SS's Avatar
Correct me if I'm wrong Mitch, but I heard this year that NASA (and some other HPDE places following the heard) are requiring back braces on all fixed back seats put into a street car? Have you heard anything about this?
Old 09-16-2011, 03:59 PM   #7
mitchntx's Avatar
Quote:
No, I haven't heard that. but it wouldn't surprise me.
The unsupported upper section sees probably 90% of the G-Forces in an impact.
Related Topics
Thread Thread Starter Forum Replies Last Post
'02 Camaro Power Seat Unwanted/Loose Seat Movement FIX? libertyforall1776 Appearance & Detailing 7 06-11-2015 07:54 PM
GTO interior stitching bad skidmarkSS Pontiac GTO 2004-2006 22 01-28-2010 01:38 PM
seat mounting brackets Taubr Unit Drag Racing Tech 17 08-08-2007 10:19 PM
Anyone have some fixed back racing seats? EdwardL Appearance & Detailing 1 10-27-2006 01:24 AM
Fixed racing seats... ok for a DD? Lithium Drag Racing Tech 21 10-21-2005 12:35 PM
Tags
angle, back, car, danger, firebird, fixed, fixedmount, mount, proper, racing, seat, seats, street, streetcar, tubes, ultrashield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
