4th Gen drift build
#61
I water jetted the flat piece and milled the other. I have a file for the WJ part, made the block on the fly. They are cast steel. I'll have a bracket in a couple weeks that will bolt to the stock upright and do the same thing as this made from 7075. Notching/taching the halo to the main hoop tonight!!
#66
Do you have more on the BMW rack, rather curious now.
Difficult finding these kind of mods anywhere from all the googleing I have done.
#67
We have never seen anybody do a BMW rack swap but looked like a viable option because it can run spacers.
In general to do this kind of swap you will need several things:
1. Custom fluid lines because I don't think the fittings on the new rack will be the same, also might need to adjust the pressure based on the new rack requirements/limitations
2. Fabricate new mounting tabs on the subframe to attach the rack to the car
3. Custom length inner tie rods. I don't imagine a BMW has the same track width
4. Tie rod ends that are the right pitch to seat in Chevy knuckles and thread into the BMW inner tie rods
#68
#70
I put the BMW rack on hold since this bracket is a much easier/needed fix at the moment. Adding 26* over stock, looks like Im going to need a 9" wide wheel with a 10-15mm offset or more. I'll know more on that setup next week when I bolt it on. If its not enough angle then I'll add the E36 rack. I once fabricated a Mustang II rack to fit on my Fbody, much more challenging than putting this E36 rack on.
#74
Every time I plan to work on the car I get an emergency order for something. Plus all the other jobs I have in line already. Its a good thing money wise, but personal time is really hard to come by these days. I need to just take some PTO days at my day job and build the car
