Road Racing Road Course | Autocross
Clutch?
Old 03-24-2013, 10:51 PM
94LS1B4C's Avatar
Default Clutch?
I found out that the slave cylinder on my 2001 ws6 needs to be replaced. The car is a weekend car with full suspension and attend autocross/open track day or time attack events. It has a tick master cylinder and was told to pair that up with a regular gm slave cylinder and thought while i'm in there I might as well replace the clutch. Does anyone have any recommendations for an aftermarket clutch? I've been thinking about lightweight options such as maybe the RAM billet aluminum flywheel paired up with an ls7 clutch? Curious to see what you guys think....
Old 03-26-2013, 12:30 PM
1981TA's Avatar
I went with a ACT lightweight steel flywheel on mine. The general consensus on the slave appears to be stick with the GM unit if you can, and look very carefully at aftermarket- they are not all up to OE quality levels. I went with a Spec provided slave in mine, plus a remote bleeder (which I highly recommend). I've not had a peep of trouble out of either part.
Quick Reply: Clutch?
