Oil pressure drop after running on a hot day?
Just wondering if it's entirely normal for idle oil pressure to drop to 20-25 psi after 10-15 minutes of running hard on a 90-100° day. I understand the oil's getting heated up and thinning out, but my buddy's Cobra, for example, doesn't see a drop in pressure after doing the same run.
Is this normal or is it an indication of internal wear, and would an oil cooler entirely eliminate this?
i would say its normal.it does get pretty hot..if your worried about internal wear next time you change your oil look for any metal shavings..ur car consuming oil ? smoke?
What is your oil psi while racing? I found mine dropping to 15-20 psi at wot because I was not running the right oil and running north of 300 degrees. I switched to Mobil 1 0-50 RACE oil as well as getting the biggest Setrab oil cooler I could fit 18x12 in the grill area and things went to where they should. If you are going to do it on a regular basis an oil temp gauge would be a good investment as well as better oil and a good cooler. Good luck.
I've been running basic Mobil 1 5-30. My only question about race oils is whether they would do any harm to a car that's daily driven and won't see high oil temps most of the time.
I ran a 30W in my LS7 and oil pressure at the road course was not good (no oil cooler). Hot it would drop to 10-12psi at idle after a 20 minute pounding on the road course. Also hot idle on the street was a bit low.
Switched to 40W with a small non ducted oil cooler..... much better (20-22psi hot after a lapping session). Finally swapped in a much larger oil cooler with ducting and have yet to try it out.
Any road racing should have an oil cooler properly ducted on the car. Especially in 100* weather.
