17" vs. 18" wheels and tires
For some reason i'm struggling with this question...
I do lots of autox and lapping and i was wondering what your opinions are on running a 17 inch wheel vs. an 18 inch wheel and why? i currently run the stock ZR1s 17x9 50 offset for autox and replica 17x9.5 z06 alcoa style wheels from oe wheels for lapping which are serving their purpose for a 25lbs wheel.
I could go 17x11 but they are heavy and given the tire option not sure if i should stay in the 17s or go to 18s...the latter certainly opens up the tire options but of course, at a premium.
perhaps i have answered my own question...or i am making it more complicated than it is.
thoughts?
thoughts?
If your focus is on weight and / or cost of operation, I'd stick with 17x9.5. On a lark, I went around the paddock at the June Sprints and looked at what all the competitive pony cars were running. Nearly all of them had 275-40 17s on all four corners. I'm guessing this was for a combination of reasons:
Little benefit in going with a wider tire
Larger hoops weigh more - increased unsprung weight
Huge selection of tires in this size
SCCA Class restrictions.
On tires of the same diameter, larger wheels equal shorter sidewall (harsher ride, potentially smaller contact patch)
Thank you for your feedback gentlemen.
weight is def. a factor in my decision...for what i'm doing, it's important to keep the weight down.
The motivation for looking at 18" setup is because the BfG Rival, StarSpec, and RS-3 are all only available in a max width of 255mm in the 17"...to get to 275mm you would need to go to 18".
What did you end up deciding on? I am also debating what tire/size to go with for HPDE/getting started w/ RR. Will have to do double duty for a while until I can get a second set. Considering sticking with my 17 x 9 WS6 rims and getting something like a RS3/RE11/AD08/NT01/RA1/AD48 or going with 18x 9.5 OE wheels C6 Z06 style to open up the door for a BBK in the future. Doing the research now and any opinions from people that have actually tried any of the above would be helpful.
One thing that may help you decide is looking at tirerack and seeing what tire options are available for the wheel sizes you are looking at. With your given width (9.5) you are probably looking at either 275/40-17 or 275/35-18. While I based my decision on price, quality and weight, you may have different motivations (like appearance).
My wheels were 100 a set (3rd gen corvette saw blades, 4th gen camaro SS), and the tires were 100 each for continental RR slicks and 140 for continental DW extreme summer tires. I have a total of 1300 or so into TWO sets of very good new tires and good wheels. Granted, the wheels won't win any beauty contests, but I don't care. 17x9.5 OE wheels are plenty light and cheap.
Another set of wheels that can be had cheap are 18" corvette "wagon wheels." They ain't purty, but they are VERY light.
I bought a set of Zr1's like this and they have held up very well.
Wrong, I couldn't disagree more with this.
18 inch wheels do weigh a LITTLE more but not by much and actually i'll be making a thread for some enlightment in this subject.
18's you see a lot in autox and time attack. Why? Because of less tire flex along with more stability, less body roll, and more planted to the ground. 17's a lot of the time you will need more extensive alignment to achieve 100% contact patch out of your wheels and tires. And wider is not always better there are certain extents based on your suspension to be able to get a full consistant contact patch throughout your tires tread.
So... That is all.
So... That is all.
So... That is all.
The inertia in the bigger wheel is higher, therefore it takes longer/more power to accelerate it and longer/harder to slow it down.
Smaller wheels and less rotational weight are proven faster, in every facet of any type of racing. What tire aspect ratio you put on said wheel is up to you.
How does the tire on a different wheel have ANYTHING to do with body roll ?? More grip makes body roll worse, tire flex is a function of the tire carcass, not so much the wheel itself.
A wider tire is always better on a higher powered car, Miata not so much. On a low powered car there is a point of diminishing returns.
Take a 275/40/18 against a 315/35/17 and I will outrun you on my car with the 315/35/17. More grip means more cornering speed, period.
Contact patch is a function of MANY things, mostly wheel width vs tire size and pressure. Once you start driving the car harder, camber angles come into play.
If you look at a racecar, they only have wheels large enough to get over the brakes on the car.
So, you think 2-3 lbs of rotational weight means nothing? It's is without a doubt significant. 2-3 lbs less rotational weight is like taking 20-25 lbs of static weight out of the car. There is a rule of thumb or formula somewhere.
I may still be thinking in terms of motorcycles but overall generally are similar in terms of less side wall + softer tire = more grip. So your 315/35 compared to 275/40 true. But what about a 295/35 or 305/35 compared to a 315/35?
I was throwing out a general statement but in terms of tire and wheel size compared to suspension components they can be balanced out fairly well correct?
I agree with a lot of what you said but weight of the wheels comes into play to I think in terms of this a 20lb 17 inch wheel is the equivalent as a 18lb 18 inch wheel.
You did not address the 18 inch wheel being lighter, you said heavier.
Suspension components have nothing to do with inertia and how it works with brake rotors and wheels/tires.
You take weight away that the shock and spring don't have to control it makes their lives easier.
A front C5 Z06(17) wheel is lighter than a rear C5 Z06 wheel(18).
Same size tire dimensionally on say a set of front C5 Zo6 wheels 17x9.5 vs a set of C5 Z06 rears . The 17 will be faster.
Its WHERE the weight is in the wheel, the further out the worse it is as far as Inertia goes. In a wheel most of the weight is in the barrel.
I'm still interested in going with an 18x9, 10 or 10.5 because it opens up some interesting tire options. so my thinking is that if i get better tires i wouldn't need a BBK since the tires i'm looking at have better grip meaning reduced stopping distances and coincidentally, more cornering speed...
i found a set of 18x10 OZ wheels which i plan on checking out but they are not cheap.
