Road Racing Road Course | Autocross
How do you guys make more power?
Old 06-28-2016, 09:09 PM
M4N14C's Avatar
Default How do you guys make more power?
Just wondering how you guys go about making more power. HCI? Turbo? ProCharger? I'm mostly done with upgrading my suspension and want to choose a path to make more power but not sure which to choose for a car that will see corners. I'd assume HCI since it's the lightest but would like some opinions.
Also Nitrous is ruled out due to the fact that most SCCA events prohibit the use of Nitrous.
Old 06-28-2016, 09:39 PM
Steve91T's Avatar
Stickers.
Old 06-28-2016, 10:39 PM
Steve91T's Avatar
Stay away from FI...too many heat issues. A cam can give you 420 to the wheels. Are you just doing HPDE's?
Old 06-29-2016, 06:18 AM
RAMPANT's Avatar
Bored and stroked LS7, ITB intake and all the bolt ons.
Old 06-29-2016, 06:54 AM
scotty2000ss's Avatar
Telling us your budget would help.
Old 06-29-2016, 07:42 AM
RidetechJosh's Avatar
Agreed. I've had better luck with a nicely built engine. For a roadcourse/autocross, the FI cars seem to struggle a little.
Old 06-29-2016, 08:28 AM
3.8redbird's Avatar
I plan to roadrace in my vette but not competitively. To much power with a vortech.
A nice high revving aluminum engine with an impressive midrange tq curve is all you need. I was always told 700rwhp is the most that is doable in roadracing for a streetcar.
Old 06-29-2016, 01:11 PM
M4N14C's Avatar
Not really set on a budget yet, though I'm thinking around 4k-5k.
I will be doing HPDE's as well as the occasional autocross. What kind of cams are you guys running?
Old 06-29-2016, 01:26 PM
Steve91T's Avatar
Wait, you don't have long tubes? Man I'd start there with a tune. Gotta do it anyway. To give you an idea, an LS6 cam and tune with allow you to pull to 6500 and make about 380 rwhp. There are better came out there, just giving an example.
What kind of lap times are you running at VIR? I don't know you're experience, but power should be absolutely last on your list. Driver experience should be number 1.
Old 06-29-2016, 03:27 PM
M4N14C's Avatar
I'll be getting a full Kooks Dual exhaust with longtubes here in the next couple months. There's no rush I'm just trying to see what works and what doesn't when I do want to make big power. Right now I'm making 333rwhp which is very manageable for autocross.
Since I live in Seattle, there are only one or two tracks in this area both of which I haven't yet run at. I've mostly done autocross.
Old 06-29-2016, 04:14 PM
Steve91T's Avatar
Oh ha, I thought you were in Richmond VA.
Old 06-29-2016, 11:39 PM
Steve91T's Avatar
Do LT's and a tune and leave it. You'll have way more power than you have experience.
Old 07-04-2016, 10:01 PM
.boB's Avatar
A lot of good advice there. When setting up a car for the road course, the engie is about the last thing to look at. The further you go away from stock, the less reliable it becomes. You can't win if you can't finish.
1. One on one instruction
2. tires
3. Seat time
4. brakes
5. Seat time
6. suspension
7. Advanced instruction
8. Engine
9. Seat time
Old 07-05-2016, 08:24 AM
HioSSilver's Avatar
Are you looking for more power or better acceleration? They are not the same.
Old 07-05-2016, 12:47 PM
SAPPER's Avatar
I just finished a head/cam install on my sons car. Getting tuning done tonite. But He took the cam route via a BTR roadrace cam with 243 heads.
A cam designed for a purpose will net more productive results without wasting money.
He doesn't list this cam on his site, but give his folks a call and they'll take care of you. All I know is this cam kit with 799/243s are well into the 4xx rwhp.
Old 07-06-2016, 05:56 AM
beach cruiser's Avatar
I would also add a good diff to the list. I run an Aurborn Road Race diff in my WS6, made all the difference in the world for autox. Tires, seat time and brakes. Get rid of the drilled rotors and go solid with some HAWK HP+ pads or similar.
Old 07-06-2016, 10:20 PM
M4N14C's Avatar
If there's a way for faster acceleration other than gears or drastic weight reduction, I'm all ears
This is probably the route I'll do first.
Diff is definitely on my list. Will deal with brakes once I do the CTS-V swap, so far brakemotive has served me well.
Old 07-07-2016, 06:55 AM
Are the ctsv breaks heavier?
Old 07-07-2016, 07:21 AM
HioSSilver's Avatar
Weight reduction always plays a part. You can get quite a bit of weight outta these cars vary easily and sacrifice nothing. Likely wouldn't really need those heavier brakes then either.
Clutch weight would help you to. For road racing especially you want something as small and light as possible.
With your kooks system you will gain alot. Throw a fast intake on that too along wuth a larger maf and you will pick up alot of power.
Another good idea again especially fir road racing would be a good set of valve springs. Roller rockers work well to.
With the mods mentioned you won't hardly know your car when you step on the gas.
Old 07-07-2016, 11:34 AM
Midnight02's Avatar
I originally built my car as a straight line car and then got hooked on road courses. Here are a few of my thoughts based on your question, comments about your goals for the car and your experience on track:
1. .bob is correct -- seat time is the single greatest factor of lap times at this juncture. Engine power is not the biggest limitation. I remember pointing by a Mini Cooper at my first HPDE at Road Atlanta despite having 3x more horsepower on tap. The person behind the wheel of that Mini Cooper was an instructor. Ever since that humbling moment, I've sought to improve my skills as a driver instead of focusing on the car.
2. Brakes: Before you lay out the coin on a big brake upgrade, you should put a set of track pads on the front with blank rotors and gain some experience. I have the stock LS1 brakes on my car with an aggressive track pad (DTC-60 or DTC-70 up front) and the HP+ in the rear. Frankly, you would be well served with a HP+ in the front and a parts store pad in the rear. Don't feel motivated to upgrade the rear brakes substantially -- due to the braking bias for our cars, that will only create problems with wheel hop.
3. Accelerating faster: It's amazing what a lightweight clutch and flywheel can do in this regard. Sure, the car is tougher to launch at the drag strip, but it rips through the gears on track. There are plenty of great lightweight combos out there -- I'm running the McLeod RST with the lightweight aluminum flywheel. Sure, there's a great benefit here, however again this isn't a limiting factor on track right now.
4. Engine Mods: To the extent you want to produce more power, I would recommend going N/A as forced induction is known for having heat-related issues. A simple heads and cam combo can be quite potent when matched well with supporting mods. The cam profile you should be looking for is one that makes good midrange power. I went with a 228/230 custom grind cam that isn't worthy of a dyno-brag post, however it is solid at producing power where I need it.
5. Tires: The engine mods don't really matter if you can't put the power down to the pavement. Tires are a HUGE factor in lap times and performance, however you should get more seat time on street radials. One of the best benefits of tracking these tires is that most provide good audible feedback as you approach their cornering limits. Having that sound to go along with the feel goes a long way in helping you fine tune your feel for where the limit is. R-compounds are great and will certainly push the "limit" further out in a good way, however they don't produce the same sound as you get closer to that point. Generally the way you know you're approaching the limit of a R-compound is 100% feel or the you'll get a clear reminder where it's at every time you step over it (and then it becomes focused on recovery of control).
6: Suspension mods: I didn't start doing the suspension work until after my first HPDE and I'm glad I waited. It was good to get a feel for the car in stock form and then it made it easier to recognize how each individual component made positive contributions to the handling of the car. Shocks are a worthwhile upgrade as well as sway bars. I consider springs being paired with shocks, so you could group those together as one upgrade. I do have roto-joint LCAs and they've been great at helping put power down to the ground and I don't have to deal with articulation limits or binding.
Quick Reply: How do you guys make more power?
