To Stroke or not to Stroke - LS1TECH
Road Racing Road Course | Autocross
Thread Tools Search this Thread
Old 11-14-2016, 08:34 PM   #1
southern69chevy's Avatar
Default To Stroke or not to Stroke
I have a fox body that I'm building that I would like to compete in the optima street car challenge with, but mostly it'll be a fun street car that i will autox.
Now, I have a stock short block lq9 and t56 sitting in my garage, along with a 4" crank and rods....just need pistons. I was originally planning on stuffing it into a drag car, but I've been heavily considering sticking in the fox.
Would a 408 stroker be too much for a fox to autox or should I just build the stock lq9?
southern69chevy is offline   Reply With Quote
Old 11-16-2016, 12:55 PM   #2
FIVEPOINT7's Avatar
I would just build the stock LQ9, horsepower has such a minute effect in AutoX and Road Racing that it's not even funny. The money you would spend stroking it added with the additional piston skirt wear etc would be a waste IMO.
FIVEPOINT7 is offline   Reply With Quote
Old 11-16-2016, 03:38 PM   #3
I agree. Freshen up the motor, maybe a little cam if you want and a little head work to support but make it reliable as possible. Then spend most of the money in suspension wheels and tires.
Friend of mine (that got a invite to SEMA for OSUSC) was able to drive Danny Popp's newest C5Z street car that is basically stock with JRI shocks. My friend owns a built C5Z making somewhere 550-600 rwhp and can wheel that car amazingly well.
He was within .3 seconds in his own car and Danny's car same course/same day....that proved to him (and me) power is not always the answer.
BUT, as you know in OPTIMA stuff you are up against a lot of 500+ hp cars that on a road course may pull on you.
To get your feet wet, a rock solid motor/drivetrain with EVERY Foxbody suspension part.
Tubular K member/control arms (save weight)
PHB and TA setup or a Watts Link
Coilovers
Decently wide wheels with the best 200TW tires you can buy (currently Rivals)
A solid 400-450 hp "stock-ish" LS motor in a smaller Fox would be good power-to-weight.
smitty2919 is offline   Reply With Quote
Old 11-20-2016, 08:33 PM   #4
gnx7's Avatar
Danny Popp's car runs a 388ci (4.125" bore/3.622" stroke) setup that revs to 9000rpm.... I wouldn't exactly call that stock
He also runs a crazy light Tilton 5.5" triple disc clutch/flywheel combo for super fast revving engine. It works for him that is for sure.
My buddy Rich Wilhoff runs the yellow C6 Z06 with a built 427ci from Katech (4.125"bore/4" stroke) keeping revs under 7K RPM and was also in the Optima challenge and won the series overall.... just not the winner takes all event in Las Vegas. His car makes around 575rwhp and 80rwtq more than Danny's. Rich said he doesn't want to give up the torque...
I would say more cubes and therefore torque is preferable unless you have big $'s to make a high revving short stroke setup.
If you are serious about AutoX or road racing you want an aluminum block. An engineer would give his left nut to shave 80lbs off of the front end of a car.
gnx7 is online now   Reply With Quote
Old 11-21-2016, 07:25 AM   #5
Quote:
His A Street C5Z is a stock motor with only shocks/springs.
AFAIK, he has:
Optima C5Z (front splitter/spoiler)
Full road race C5Z (gutted/caged etc)
Stock C5Z (shocks/springs only) newest addition
The '72
Old 11-21-2016, 10:50 AM   #6
redtan's Avatar
On a light car and for autox I wouldn't bother to stroke it.
Now on a heavier car and on an actual road course it would be nice to have all that extra torque all over the RPM range.
redtan is offline   Reply With Quote
Old 11-21-2016, 10:54 AM   #7
LS1Tech Premium Sponsor
Aaron at SDPC's Avatar
I definitely don't feel like the longer stroke is needed for what appears like it will be a light weight setup. Plus the stock stroke will promote longer engine life which is plus in my opinion.
Aaron at SDPC is offline   Reply With Quote
Old 11-21-2016, 11:11 AM   #8
1981TA's Avatar
I'll add that a lot a horsepower can have a negative impact on autocross. I have a hell of a time balancing throttle and grip on my car. It requires more concentration than I'm happy with. This, in turn, can distract from the stuff you should be paying attention to on the course.
1981TA is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
7K Fox Body Street Build rkulp89 Conversions & Hybrids 25 01-21-2017 11:33 PM
Lq4 foxbody build questions Klongstreath Generation III External Engine 3 12-20-2016 05:26 PM
LS fox body question on radiator/fans Strokin_6_Oh Conversions & Hybrids 2 06-05-2015 09:28 PM
should I sell the SS for a fox body? streetassasin Racer's Lounge 40 07-21-2008 10:29 AM
LS7 into a fox body? SVThis Conversions & Hybrids 4 08-04-2007 01:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
