Initial soft brake pedal? pad knock-back? - LS1TECH
Road Racing Road Course | Autocross
Thread Tools Search this Thread
Old 03-17-2017, 09:20 AM   #1
Default Initial soft brake pedal? pad knock-back?
This is not a "new" condition for me that I have noticed but maybe I'm getting a little more annoyed with it.
I have this condition even driving on the highway and getting off coming to a stop. The first time I hit the brake pedal it will feel soft and travel farther than expected. Once the first initial pump is done, the pedal travels less and grabs sooner.
I thought this only happens during racing for people but on the highway it's slightly unnerving when you have a "oh ****" moment and need brakes instantly (happened last night when someone didn't know how to merge...)
95 Z28
Ls1 Front brakes stock rear
Hawk HP+ pads front Duralast rear
pads and rotors are not worn out
no leaks in system
(will need to verify fluid level but this has happened when fluid level is OK)
Rocketman1 adapters with SKF hubs
No ABS lights or issues
Is this "pad knock-back"?? If so I thought this happened when hubs were deflecting and pushing pads back into caliper **while racing not DD**...but with the SKF hubs I figured this solves that issue.
smitty2919 is offline   Reply With Quote
Old 03-17-2017, 11:04 AM   #2
M4N14C's Avatar
I assume you know how to properly bleed the system and have done that. How much play do you have in your rear axles? Might need new c clips if more than 1/8 of an inch or so.
M4N14C is offline   Reply With Quote
Old 03-17-2017, 11:10 AM   #3
It can happen on the rears too, but to a lesser extent. I have a video of rear discs moving/angling around a lot more than I ever imagined.
Chris Paveglio is offline   Reply With Quote
Old 03-17-2017, 11:13 AM   #4
thunderstruck507's Avatar
I had this problem after a while with LS1 rear discs swapped onto my Chevelle axle housing. It was every time I turned right, axle would slide in the housing and push the piston back in the caliper.
I replaced the C clips and also put new clutches/shims in the Eaton and it went away. Not certain which cured it or if both helped.
thunderstruck507 is offline   Reply With Quote
Old 03-17-2017, 11:53 AM   #5
Car has a TruTrac (put in maybe 2 summers ago), original c-clips. Never thought that c clips would "wear" lol.
Now, I have put in longer ARP studs in the rear in which I tapped the old ones out with a hammer. I can't imagine this "flattening the c clips to the point it allows more axle movement.
So you guys thing it's coming from the rear more than the front given I have brand new SKF front hubs?
Old 03-17-2017, 11:57 AM   #6
Quote:
I have not bleed the system for a while, but last time I did it was PS RR, DR RR, PS FR, DR FR.
I then cracked the bleeders on the distribution block as well.
Is there a "spec" to measure axle movement and if so what specifically are you measuring for wear if there is excess movement?
Old 03-17-2017, 12:03 PM   #7
SoFla01SSLookinstok's Avatar
Not saying this "is" your problem. First thing that came to my mind is the master.
SoFla01SSLookinstok is online now   Reply With Quote
Old 03-20-2017, 07:05 AM   #8
1981TA's Avatar
Check if your caliper sliders are functioning properly. These are the greased posts that the caliper mounting bolts connect to on the caliper mounting bracket. If these are not working properly, the calipers won't move with the axle when there is side-to-side movement, or center automatically as your pads wear.
1981TA is offline   Reply With Quote
Old 03-20-2017, 08:34 AM   #9
Great, thanks. I'll check those and or grease them anyways since I'll have them apart.
Old 03-22-2017, 09:14 AM   #10
1981TA I tore everything apart last night and found the fronts were OK with the amount of grease in them but replaced it anyways.
The rears were pretty dry and the grease that was there was more of a paste. Drive to work seemed much better. Will keep an eye on this.
Thanks again, so far the slider pins seem to be the issue.
Old 03-22-2017, 09:55 AM   #11
1981TA's Avatar
Glad to see it worked out. I had a similar problem on one of my cars, and it can certainly be an attention getter.
Related Topics
Thread Thread Starter Forum Replies Last Post
Factory ZR1 hubs vs SKF HD hubs t_raven Corvette Performance 0 05-01-2016 09:03 AM
hawk pad issues ToxicWS6 Suspension & Brakes 2 09-02-2015 01:40 PM
Brake pedal long travel only with car on. hrcslam Suspension & Brakes 20 04-26-2015 05:20 PM
Pad Knockback Issue?? Wesmanw02 Suspension & Brakes 3 04-11-2010 07:54 PM
LG Motorsports "G-Stop" Big Brakes - Post track comments mitchntx Road Racing 6 04-27-2003 10:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
