Accusump?
I run one on my C5. I don't know the difference of a C5 or a Fbody pan. I would say that you might want to get one if you are getting serious into tracking your car and if your car has some stick around the corners.
Hmmm...I will have megastick (car is an RX7 w/LS1 on huge tires) and it'll be used for the One Lap of America race where breakdowns pretty much spell doom.
Thanks for the replies
Ben
Ben
Listen to Louis ... he has a little experience road racing an LS1 based car.
I run 7 qts without an issue. My car has 80K miles ...
To answer your question, the LS1 pan is baffled, but prone to oil starving when the oil level gets down below 6qts. It is particularly vulnerable on long left hand sweepers where the oil can escape the baffle from around the oil level sensor "hole".
I have an accusump
But I'm totally paranoid about my engine. I don't even autox - just drag race. I've got a delay timer so the engine is always pre-lubed when it starts. Oil tests show a significant improvement in wear...
http://ls1m.com/accusump/
Never finished the site after I remounted it. Couldn't find a better place, so it's tucked up between the crank pulley & radiator bottom. Necessary? Probably not at my level. Worth the peace of mind, though.
-Mark
-Mark
I was under the impression that the F and Y bodies used slightly different oil pans and that the Vette had a higher claimed/recommended oil capacity. Is 7 quarts cool for a stock F body pan as well, or is that going to start dragging on the crank?
Originally Posted by Louis
If you are running 1 lap, the tires are not that sticky as compared to a hoosier or Toyo Proxes T1s. On top of that, you get what, 4 laps per little session? 8 laps total at any given track?
Not enough to need it IMO.
Thanks again. The car (RX7 with an LS1) will weigh a little over 2600 pounds and have 275/315 tires which is why I said "megastick." While I'll be using street tires for the One Lap, I do plan on running R compounds for track days.
In any case, I'll put this mod off until I notice issues with the oil pressure. Putting in 7 quarts is a whole lot easier/cheaper.
Ben
Ben
If you use the Accusump as a pre oiler, then when you flip the switch to fill it up again does the oil pressure drop enough to make the engine knock. The only one that I have ever seen had a manual valve and when the valve was opened to pressure the sump, it knocked. Is this normal or just an engine with bad bearings?
I've run six SCCA races in a 2002 Camaro and blown three engines. All three have spun rod bearings and thrown rods. I shift at 6000 rpm, use Mobil 1 oil and use GM or Federal Mogul bearings. Same failure with "crate" motor and "blueprinted" engine.
The SCCA does not allow Accusumps in my class, if your class does, run one!
