Tru-trac on the street???
i'm considering running an eaton posi unit in my new moser 12 bolt but the merchant i'm buying from (thunderracing.com) also offers the tru-trac posi along side the eaton - my question is, how does the tru-trac perform on a daily driven car???
i know the eaton was designed to be a street/race type so it won't give me any issues, but i'm hearing some really good things about the tru-trac when it comes to racing.
I'm a fan of clutched type differentials, the tru-trac seems to be helical which will be smooth, and feel more OEM.
However with carbon fiber clutched differentials you still attain that smoothness with more reliable/consistent locking coupled with a much higher initial torque.
I have personally seen carbon setups perform better on road race applications.
Here's a ok read on carbon diffs:
http://www.carbonetic.net/products/carbonlsd.html#
Many OEM diffs are now coming with Carbon clutched LSDs as compared to the old helical geared and viscous LSDs
Originally Posted by dailydriver
Do all of the Nippon carbon clutch pack diff manufacturers also REQUIRE the use of mineral based gears oils (like Eaton does), or have they found a way to allow synthetics to be used??
I run the carbonetics metal LSD (18 plate, 120 lb/ft initial torque) in my car and I use their oil, i'm pretty certain it's a mineral oil, however, i'm not sure. I'm also not sure if it differs between metal and carbon setups either.
Mine is metal, it grabs extremely hard, and sounds like I have a broken axle every time I make a slow, tight turn.
Originally Posted by Shock Hawk
I like the comparison graphs between their carbon fiber and metal clutched LDS's. I wouldn't have guessed that carbon fiber would last so long. Too bad they make LSD's for every manufacturer except Ford and GM.
Yeah, the carbon stuff lasts a lonnnnnng time.
It does suck, considering there's such a massive aftermarket, just look at this forum.
people need to write some letters!
The Nippon market does have some cool stuff for their rides (relatively low cost sequential gearboxes, these diffs, etc.). It's a shame most everything for our cars is sooo drag race oriented.
Yeah, the closest we get to that stuff is the aforementioned Eaton c.f. clutchpack units, which do seem to be holding up, from what I hear.
with the whole "drifting" thing, it's a good chance to write letters and show there's a market for the japanese manufacturers to make quality products for US market cars.
well, steel for drifting is actually better, I run steel.
The carbon fiber is very beneficial in road race and autoX settings because of it's smooth, progressive engagement.
Sam Strano ought to chime in here as to availability and torque ratings of the various Eaton w/steel, or Eaton w/Carbon, or the Detroit TruTrac w/gears.
He's a big fan of the Torsen gear driven race diff available for the stock rear axel.
Steve
Steve
