FS: 2002 C5 Z06 - Track/AutoX Car - Houston TX
Year: 2002
Make: Chevrolet
Model: Corvette
Price: $21000
Mileage: 89000
Location (State): TX
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
I am asking $21,000 OBO. This price is negotiable. If it seems steep - keep reading. If it still seems steep and you are actually interested, do not hesitate to email/text/call me with a reasonable offer.
The car has been outfitted pretty thoroughly for track use (no roll-cage) with high-quality parts and has always been well maintained in that aspect. I have never skimped on maintenance, fluid types, or any care otherwise taken with the car mechanically. The miles are a bit high, but for ~3 years it was also my daily driver.
It is currently located in the Heights area of Houston, TX. I have a trailer and can deliver it within a relatively local distance. At its current ride height (which is adjustable on 'drop bolts') I would not recommend driving it on anything but a known smooth street.
The car includes a binder full of receipts that tally up to an intimidating amount, and has also had a bit of maintance work done (door control modules, replaced weatherstripping, etc) in its recent history. The paint is probably the only downside to the car, as the clearcoat has been showing slight wear around the edges/near badges.
Currently it has some Recaro SPG seats installed, which I will be willing to throw in (with very fresh Schroth harnesses) for $2,000 extra. I am not looking to sell the seats, but if you are looking for a car to buy and immediately take to the track, we can work something out. Otherwise, the Recaros and harnesses are not included. OEM seats in great condition are included, as are seat rails from Hardbar and a Brey-Krause harness bar. The car has full HVAC functions as well as working stereo and full interior carpet/headliner. Also included is a spare driver's-side door card.
The car is very capable, and very quick in the right hands. It is not uncommon for me to pass 500hp C6 Z06's on Hoosiers during track days (obviously this is very driver-based) - keep in mind this car is on NT05 street tires. The best times I've personally seen have been a 1'25.9 at MSR Cresson (1.7 mile, CCW) and 1'45.4 at MSR Houston (2.8 mile, CW).
Contact: j(dot)matt(dot)davis(at)live(dot)com
Phone: (seven13) two08 - seven369 (text preferred)
Please do not PM me here as I have this car listed on several forums.
I can provide a detailed mod list upon request, for now here's some of the goodies:
Engine
Powerbond 10% underdrive crank pulley
LG SuperPro 1-3/4" Longtube Headers
High-temp ceramic coating on headers
Custom 1-piece x-pipe, v-band flanges
Pfadt Race Engineering - 95a durometer engine mounts
Dyno tune by Louis Gigliotti - 380whp/375lb-ft (have chart)
Ron Davis racing radiator w/ integrated oil cooler
Braided "Star Lite" hoses for oil cooler
Suspension/Chassis
Pfadt Race Engineering polyurethane bushings on control arms
SKF wheel bearings
Race alignment by Texas Track Works in Fort Worth
LG tunnel brace - aluminum
Pfadt "Pfatty" Low-Rate racing sway bars w/ spherical end links
Pfadt rear lower shock mount spherical bearings
Brakes
Doug Rippie stainless front pistons
New OEM Calipers - March 2011
Brakes rebuilt in March 2011 w/ install of pistons
LG spindle-duct kit w/ high-temp hose (have 8 feet of spare hose)
Doug Rippie brake ducts
Transaxle
OS Giken SuperLock 1.5-way clutch-type LSD - March 2009
OS Giken Fluid used - changed regularly
Hardened output shafts - March 2009
New micropolished Ring & Pinion - March 2009
B&M short-shifter
Pfadt Racing Tranaxle mount/brace - 95a Durometer
Spec Aluminum clutch/flywheel - Stage 4 - 38lb - Fall 2010
ARP flywheel & pressure plate bolts
Tickshift Tilton clutch master cylinder
Body/Interior
Brey-Krause harness bar (does not include harnesses)
"Heel-Toe" matching aluminum gas pedal (1.5x wider than stock)
Pfadt tow hook (rear)
Wheels/Tires
(4) 17x9.5 C6 Z06 replicas - Black
(4) 17x10.5 C6 Z06 replicas - Black
275/40/17 & 295/35/18 Nitto NT05 - 8 tires total, varying life
(2) 8.5mm hubcentric front spacers
(2) 16mm hubcentric rear spacers
ARP extended wheel studs
Some pics (originally posted several but they're huge - will resize and upload later):
http://youtu.be/V1fvNbFBcSU
