MISC Stuff: Holley 90mm TB, LS7 Fuel Rail, CMP Sensor, LS6 Coolant Tubes...PICS
Old Dec 31, 2006 | 09:30 PM
Ferocity02's Avatar
Default MISC Stuff: Holley 90mm TB, LS7 Fuel Rail, CMP Sensor, LS6 Coolant Tubes...PICS
Please PM me with questions, thanks!
Holley 90mm Throttle Body: This thing is the best looking 90mm throttle bodies I've ever seen. It only has 1667 miles on it. I used it on my 427 and it worked flawlessly. The throttle shaft rides on actual bearings, most other TB's don't. It is in perfect condition except for a small scratch on the top. Doesn't come with sensors but you can use the ones from your stock TB and they bolt right on. Comes with mounting hardware and a throttle cable bracket. SOLD.
LS7 Fuel Rail: A MUST if your using the LS7 manifold. Attaches directly to the LS1 fuel line. Has 1667 miles on it. Perfect condition... $90 shipped
AC Delco Camshaft Position Sensor: Has about 55k miles on it. I bought a new one because I thought it was causing a problem, but it wasn't. $25 shipped.
LS6 Coolant Crossover Tubes: Have two from my 427 build. They are the tubes that crossover between the heads and are necessary for the installation of LS6 manifolds. You can use one in the front and block off the back, or run one in the back and front and run a coolant line from the back to the front and use a T-fitting. SOLD.
Old Jan 1, 2007 | 09:13 AM
Z28FirefighterI1's Avatar
Pm sent on the coolant tubes.
Old Jan 1, 2007 | 04:59 PM
Ferocity02's Avatar
PM Repied, TTT
Old Jan 1, 2007 | 07:53 PM
Ferocity02's Avatar
Coolant tubes are sold, TB is pending sale. Thanks guys!
Old Jan 2, 2007 | 10:52 PM
Ferocity02's Avatar
CMP and fuel rail are left!
