Injectors are not grounding.. where in the pcm do they ground from?
Hey Jay I got the pcm. Thanks again man! Still doesnt work. I am gonna go get a noid light today and check that and if all is good then I know it is my injectors
Thats true but I cant spend that much on stock injectors. I can get a good set of 30#s for that. I just ordered a stock set fresh out of a running ls1 so hopefully they will work
Does anyone know? i did a ls1 swap into my 95 and everything works great except I cant get the injectors to open up. They were cleaned when I bought them as well. I though it might be the vats but it wasnt. What wire from the pcm grounds the injectors? Anyone know? Thanks in advance
I would check with a "noid" light. I have seen many times, after cleaning injectors, them not opening. I think its from the pintle and seat being so clean they kind of jam together. I seen it many times. If this is the case, the easiest thing to do is to buzz the injectors with a buzz box and tap on them with a brass punch and hammer.
First thing you have to determine though is if indeed you do or do not have an injector "pulse".
