Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
LT1 ignition parts, PCM, LS1 brake parts
Old 05-28-2013, 10:42 PM
blue94's Avatar
Default new optispark, plugs, msd wires, LS1 spindles,
Category: Engine - Electrical
Price: $0
Location (State): MO
Item Condition: Brand New
Engine: LT1/LT4, Small Block
LS Engine?: Non-LS Part
8 NGK TR55 GP - These are the platinum TR55's instead of the V-power copper plugs
- $25
5 NGK TR55 V Powers - These are the standard TR55 plugs
- $10
1 Set of MSD wires for LT1 Camaro or Firebird 93-97 - Missing the coil wire for the early style 93-95 lt1 coil, but still has the later 96-97 coil wire. Bought from this LS1tech vendor and you can order a replacement early style lt1 coil wire if you need to. https://ls1tech.com/forums/sponsor-s...ngk-plugs.html
-$75
1 BRAND NEW in the box NON-VENTED Optispark(for 93-94 Camaro/Firebird) Unsure of the manufacturer, but it is brand new, and I will throw in the new water pump gaskets, optispark harness(usually around $40) that goes from the distributor to the main wiring harness, and the torx socket to take it apart if you want to loctite the rotor screw and seal it up.
-$75
LS1 F-body spindles with upper a-arms still attached and good hub assemblies(came off a low mile ls1 98 trans am) Fits 98-02 or can be used to upgrade a 93-02 to the bigger ls1 style brakes
-$125
LS1 Used Front Slotted F-body(98-02) Rotors
-$50
Take the spindles and rotors for $150 - Add ls1 calipers, brackets, and pads and you have everything to upgrade your lt1 to the better brake set up.
Lokar midnight series dipstick(black finish) BRAND NEW never opened for 80 and up sbc(or lt1) mounts to header bolt:
http://www.summitracing.com/parts/lo...1/applications
-$50
Trans Am Mirror Covers - Red paint in good shape - One side is complete with good mirror/bracket/etc., One side the bracket is bad and mirror glass is broken if I remember correctly. I used the one side to replace the bracket/glass on my factory mirror. Both covers are in good shape, just not bracket/mirror on one side.
Pics of everything on photobucket,except the lt1 pcm. It looks like your typical lt1 pcm:
http://s32.photobucket.com/user/Jsch...ry/LT1%20Parts
If any of the prices seem out of line, feel free to make me an offer. Worst I can do is say no.
Feel free to pm me or call or text at 417-576-3134
(All parts are in St. Louis, MO)
Attached Thumbnails LT1 ignition parts, PCM, LS1 brake parts-img_1938.jpg   LT1 ignition parts, PCM, LS1 brake parts-img_1960.jpg   LT1 ignition parts, PCM, LS1 brake parts-img_1968.jpg   LT1 ignition parts, PCM, LS1 brake parts-img_1973.jpg   LT1 ignition parts, PCM, LS1 brake parts-img_1982.jpg
Old 05-29-2013, 05:12 PM
blue94's Avatar
I'll ship anything listed except for the ls1 spindles/hubs/rotors, those will have to be local pickup in STL, only.
Old 05-30-2013, 05:53 PM
blue94's Avatar
Somebody must need some lt1 parts...Make offers people, I don't have an f-body anymore so these are just taking up space in my garage.
Old 06-03-2013, 11:13 AM
blue94's Avatar
TTT, open to offers on anything
Old 06-17-2013, 11:30 PM
blue94's Avatar
Bump.
Old 10-24-2013, 02:46 PM
dabeav3's Avatar
still have the PCM?
Old 11-24-2014, 12:30 AM
blue94's Avatar
bumping this back up. Still have all parts except for the PCM which I have removed from the original post
Quick Reply: LT1 ignition parts, PCM, LS1 brake parts
