Turbo/Stroker 93 Trans Am FULL CAR PART OUT
Category: Accessories
Price: $1
Location (State): IN
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
Misc Engine:
LE Spec Lunati ground turbo cam. 223/223, .57x/.57x, 113* LSA -- NEVER run, only installed -- $300
PIC
LT4 Valve Covers (impossible to find anymore), two passenger side units, with 2 metco -10AN oil filler adapters ($80 for just those)-- PIC-- $250
Black Powdercoated accessory bracket, excellent shape -- PIC -- $65
BRAND NEW FRESH REBUILT Dynaspark Opti. Installed, never run -- PIC PIC-- $400
BRAND NEW Steering Rack, Napa brand -- $100
Innovative LT1 HD Battery Cable Set -- Installed partially on car, never hooked up to a battery -- $90
Black Powdercoated Throttle Cable Bracket -- VERY nice -- PIC -- $10
MSD Coil with Bracket and ICM -- Working -- PIC -- $40
Fuel System:
Stock 94+ Rails -- $25
Accel Adjustable Fuel Pressure Regulator -- $50
Home built Twin In-Tank 255 Whalbro setup w/Hobbs Switch (no wiring included) -- $250
Driveline:
SLP Line Lock, Solenoid and Lines only -- PIC -- $80
Interior:
Corbeau Targa seats. Super comfy, little sunfaded, one small hole in back side of drivers seat. -- PIC1 PIC2 PIC3 PIC4 PIC5 PIC6 -- $400 for the pair WITH brackets.
Late model T/A steering wheel with airbag -- Good shape -- PIC -- $50
MISC
LS1 front brake setup, clearanced for fitting under centerline telstar 15x4 wheels -- $100 for calipers/spindles/lines not including pads/rotors (torched)
More to come.......... Car is complete so if you need a non-performance part then just ask as it's here right now.
will the gauge cluster work in 95 trans am? master window/lock switches and bezel available? willing to separate both headlight covers from headlight buckets? car is black correct?
Gauge cluster will work in a 95, no problem. Master window/lock switches and bezels are available. Headlight covers can be separated but there is a small dent/scratch in the drivers side headlight cover (dropped hood on it when removing once). Car is NOT black, it is purple pearl metallic. PM Sent.
Adding a bunch of stuff:
AutoZone lifetime warranty reman LT4 Starter
Pics of Turbo Kit off the car
Pic of the Innovative HD Battery Cables
Serpentine Tensioner (I had another one)
Vented Opti Vacuum Harness
Vented Opti Wiring Harness
Dynaspark Pics OFF the car
Firehawk Hood
Drivers Door Switch Panel
Steering Linkage with Unbalanced Engineering Rag Joint Eliminator
Firehawk Hood
[URL="http://s72.photobucket.com/user/Fastbird93/media/For%20Sale/Trans%20Am%20Part%20Out/0512152032a_zpslbdjaiwr.jpg.html"]
AutoZone Duralast brand Lifetime Warranty Reman LT4 Starter -- $75
Vented Opti Electrical Harness -- $10
Serpentine Tensioner -- $10
