LSX harness 2000 s10
Category: Engine - Electrical
Price: $650
Location (State): WA
Item Condition: Used
LS Engine?: Fits LS Engine
Donor truck needs to be 98-2000 4.3L with 4L60e trans to function correctly.
Harness was installed on a bored LQ9 with L92 heads and LS3 intake.
The current performance harness starts at $800 with no ecu, tach module, pedal assembly or pedal harness. I have all of these items ready to be installed.
The harness is a Blu/Grn ECU,(I can write an oem tune if needed). Its setup to run ev6 (ls3) injectors, front o2's, evap (if you want to use it) and all other gen3 sensors plugs.
Only item missing is a truck DBW truck throttle body. New ones are $200, used can be had for under $100.
You get:
ecu
main harness
efan harness
tach module
pedal assembly (ready to mount)
tach to pedal harness
MAF senor
o2 senors
$650 shipped to your door or delivered within reason, you won't find a more complete harness for less.
I will take paypal as payment but won't cover there fee's if you want to use a credit card.
