87 54k mile Mustang GT Gray Metallic 13:1 E85 LS/TH400 Nitrous Beautiful Car!
Year: 1987
Make: Ford
Model: Mustang
Price: $18700
Mileage: 54899
Location (State): IA
Color: Gray
This car has hours of tuning into it, it fires up and idles perfect and runs great on e85. The suspension hooks and consistently runs high 1.3x 60’ times on motor.
The car was originally going to be a Grudge car which is why I built the nitrous motor with custom pistons good to a 300 shot, but I decided to do more bracket racing and have not really sprayed the car but a few times as it is not really necessary in that setting and just simply haven’t had the time to go out on off weekends to run it outside of bracket events. I have a brad new Nitrous Outlet Stinger dry nitrous plate that can go with the car if desired. I removed the Edelbrock plate kit off the car this winter as I was hoping to do more grudge racing this year and wanted more of a serious nitrous setup. I’ll be happy to answer any questions you may have on the car, just call/text/email. Below are some more details.
1987 Ford Mustang GT
54,855 miles before being converted to race car
10 pt MS Cage with carbon door bar covers
Rear bulkhead as required with fuel cell in the trunk
Billet Specialties 15X10 Rear with 28X10 Hoosiers, screws and tubes
Billet Specialties 15X4 Fronts w/Moroso DS2 frontrunners
Drive Shaft Loop
5 lug conversion all four corners
Kirkey Seats
Full black carpet, Full Gray headliner
ARC 8 switch Switch Panel
Autometer Gauges (3.5 Tach w/shiftlight, Oil, Fuel Pressure, Water Temp, Voltage)
Holley gage (outputs any parameter seen by Holley HP Fuel system)
RaceQuip 5 pt cam lock harness (good until Aug 15’)
Smoke Headlight and taillight assemblies (all lights work including turn signals)
Bolt-on cowl hood
Front bumper support delete with tubular reinforcements
Engine
Long block assembled by American Speed in Moline, IL (build all of our LS motors)
Ls1 Aluminu block honed to 3.903
Wiseco +12cc Pistons (13:1 static compression)
Eagle Connecting Rods w/ ARP 2000 bolts
Stock LS1 Crank
Patriot Performance CNC ported 243 heads w/ARP Headbolts
LS7 Lifters
Bullet Racing Cam (.625, .625, 254/ 268 @ .050)
Brian Tooley .650 lift Valve Springs and titanium retainers
Comp Cams hardened push rods
Comp Cams Rocker Trunion Upgrade
Melling Oil Pump
Cloyes Double Roller Adjustable Timing set
Moroso Vacuum Pump
Peterson Vacuum Regulator
Motion Raceworks custom vacuum pump pulley setup
Kooks LS1 Mustang Swap Headers (1.75” w/3” merge) Ceramic Coated
Accufab 4150 Fuel Injection Throttle body
Edelbrock Super Victor Intake and fuel rails
MSD 93 Lb Injectors (Injector size is to support dry nitrous shot)
Holley HP EFI (spark and fuel management)
Holley Solid State relay (Allows progressive nitrous control using Holley HP system)
Suspension:
AJE LS1 swap K-Member
Flaming River Manual Rack
Anti-roll bar
8.8 rear with 4.10 Gears
35 Spline axles with c-clip eliminators and spool
Lakewood 3 way adjustable shocks in rear
Adjustable upper control arms in rear
Metco (Spring on Perch) Lower Control arms
Lakewood front shocks
Fuel System
Runs on E85
Magnafuel 625 EFI Fuel Pump
Aeromotive fuel filter
Weldon Fuel Regulator
-10 Feed that Y’s into -8 feed for each fuel rail
-6 Fuel Return
15 Gal fuel cell
Transmission
TH400 w/ TCI RMVB & T-brake and extra clutch packs per gear(built by Maxwell Transmission Davenport, IA) good for 800 HP.
J&W Bell Housing
TCI Overflow Catch can
Continental Converter ~5000 Stall
B&M Stealth Pro Ratchet
Electronic VSS installed in transmission for speedometer (installed but not currently used)
You cannot even begin to build the car for this money. The car is VERY well detailed in and out, and ready to race.
Car goes 10.70 @125 consistently every pass on motor with a very conservative tune (again I bracket raced it), went 9.60 @ 141mph the first nitrous pass on 125 shot with previous camshaft (MS3). Easily a bottom 9 high 8 car with more spray. Car weighs 3100 lbs with driver and as I mentioned before is basically a full weight car. Lots to be gained from some lightweight parts and cranking the nitrous up. Selling because I found a new car that I would like to purchase and build. You won't find a nicer GT car around!
Please email dhcook1@gmail.com or call (563) 676-1255
$18,700
