99 frc widebody h/c/i
Year: 1999
Make: Chevrolet
Model: Corvette
Price: $12345
Mileage: 1000
Location (State): MO
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
160K miles (Z06 Cluster swapped with 159k miles, still have stock cluster).
Manual AC
Bose Stereo
Power drivers seat
Black interior in great shape
gauge pillar with cobalt autometer gauges, boost and fuel pressure
I have a binder of paperwork from previous owner on work done to car
tuned by Lsxkilr
Exterior Mods
Was wrapped in matte white but in the process of removing, rear fenders and bumper left
L5 rear fenders, not painted under wrap, have stock fenders still
Wheels are a true 3 piece, Competition Gold center with polished outers and black inner barrels.
19 x 9 front with 235/35/19 Continental Extreme DW
20 x 12.5 4.5" lip with 325/25/20 Continental Extreme DW
Radio Flyer light cannon head lamps with HI 4, 4300K HID and Halos
Clear corners with Amber LEDs, no fast flash
High power LED reverse lamps
License plate LEDs
Stubby antenna
20% tint all around
Debadged
Motor
shortblock built by MC Racing
forged ls1
arp 2000 bolts
ported ls6 intake
tsp stage 2.5 5.3 heads, all supporting mods
custom comp cam 595/605 223/239 112lsa
5.3 coil packs for better spark
tr5 plugs
MIGHTYM0USE stealth catch can
All new gaskets throughout, oil pan, intake, front and rear covers and main seals
1000 miles on everything
460rwhp
Exhaust
Long tube headers
x-pipe
highflow cats
borla stingers custom pipe to fit around c6z rear
Fuel system
SD 80lb injectors flow matched from FIC
ECS fuel block to -8AN
-8AN RPS 100 micron filter
-8AN into Bosch 044 -10AN out
-10AN into -8AN T where factory fuel comes in
-8AN into factory rails
-8AN out of factory rails into -8AN check
-8AN out to Aeromotive 13129 boost reference regulator
-6AN out of regulator to return to tank
Hobbs switch
Custom 12 gauge wiring harness double fuses for external pump
Custom external pump override switch above lighter
Driveline/Suspension/Brakes
'08 Z06 2.66 ratio TR6060 fully rebuilt with Carbon Blocker rings, bronze pads and new HD bearings, done by a local trans tech at the largest dealership in the area. Like a RPM stage 4. Had to replace 5th as it had a chip on it.
'09 27 spline diff RPM built changed to 30 spline input, Z06 HD output shafts and preload springs
'07 C6z cradle
RKT56 offset mounts
C6Z shifter and ****
McLeod RST twin disc
New GM Slave
Tick Remote SpeedBleeder
DOT 4 fluid
LG GT2 coliovers fully adjustable for spring rate and ride
'09 C6 Z51 Caliper and abutment brackets, smoothed, sanded and coated gloss black, fully rebuilt with new seals and cylinders
C6 Z51 stock rotors with HD Ceramic pads(1200 miles)
ATE Super Blue DOT 4 fluid, fresh flush and fill entire system
Also have stock chrome wheels and tires and custom corvette cover
clean and clear title in hand
$21k obo
dont have to sell just seeing if anyone is interested, possible trade but no junk or projects
Amen, I felt for it with you both! My eyes lit up when I saw that price soon to be ruined by the end of the description. But hey to the owner, beautiful car!
