Feeler y2k Camaro SS brand new driveline cam'd ls3, liberty faceplated t56, moser 9in
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $1
Mileage: 1500
Location (State): PA
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine:
Brand new ls3 with tick/ btr stage 4 ls3 cam, morel lifters, c5R timing chain, ls2 chain damper, ported and shimmed stock oil pump, btr .660 dual valve spring kit with titanium retainers, comp trunion upgraded rockers, comp 7.4 hardened pushrods, ls9 head gaskets, arp head studs, Nick Williams 90mm tb, tsp 1-7/8 SS headers with custom SS y pipe and custom built exhaust with dyno max bullet muffler and qtp cutout. I built this car with intentions of adding boost down the road Engine is a cam swap away from making 700+hp fi
Transmission:
Liberty face plated t56 just built around 1,500 miles ago, tick master, tick speed bleeder, new gm slave, textrilia oz700, pst 3.5in aluminum drive shaft with 1350 u joints.
Rear:
brand new moser 9in rear 35 spline, 3.50 gear, wave trac, aluminum third member, powder coated black, lca relocation brackets.
Fuel:
brand new walboro 255, stock ls3 rail and stock ls3 injectors.
Brakes:
stock with drilled and slotted rotors with ceramic pads
Suspension:
Bmr turbo k member, Bmr a arms, Bmr t56 cross member with ta relocation, founders double adjustable rear control arms and panhard bar, umi weld in subframe connectors, afco front coil overs.
Misc: Slp line lock, abs delete, lots of weight reduction ect. I'm sure I forgot some things but that's the bulk of it.
Asking 14k Obro
You can shoot me a message or call/ txt me 2158282615
thanks, John
