Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
FS: comp cam 239/247
Old 04-05-2015, 09:47 PM
SS69LS1's Avatar
Default FS: comp cam 239/247
Category: Accessories
Price: $215
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
Sold.
Old 04-06-2015, 12:30 PM
SS69LS1's Avatar
full specs from comp:
SERIAL # V 5769-11 SPEC CARD # 19758711 SPEC CARD INQUIRY BY SERIAL #
PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
CORE C54-11II CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Special Grind
GRIND # LS1 13050R /13052R HR114 + 2
DURATION @ .050 INTAKE 239 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 247 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3650 EXHAUST 1.70
VALVE LIFT INTAKE .620 LOBE LIFT EXHAUST .3720
VALVE LIFT EXHAUST .632 LOBE SEPARATION 114.0
DURATION .006 INTAKE C/L 112.0
TAPPET LIFT INTAKE 293 CAM ADVANCE 2
TAPPET LIFT EXHAUST 301 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 7 JOURNAL DIAMETER STD 2.166
VALVE OPEN EXHAUST 59 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 51 DEPARTMENT P
VALVE CLOSED EXHAUST 7 SPC INSTR FOR CUSTOMER
INTAKE LOBE ID 13050R GRIND INSTR FOR CAM SHOP
EXHAUST LOBE ID 13052R 2 DEGREES ADVANCE GROUND IN !!!!!!!!!!!!!!!!!!!!!!
DATE SETUP 04/06/2011 LOBE #S AND LSA PROVIDED BY GUERRA GROUP !!!!!!!!!
Old 04-09-2015, 06:33 AM
SS69LS1's Avatar
bump.
Old 04-11-2015, 09:08 AM
SS69LS1's Avatar
back up
Old 04-13-2015, 06:12 PM
SS69LS1's Avatar
up again
Old 04-15-2015, 02:21 PM
SS69LS1's Avatar
bump.
Old 04-18-2015, 09:22 AM
SS69LS1's Avatar
up again
Old 04-21-2015, 07:07 AM
SS69LS1's Avatar
back up
Old 04-24-2015, 03:00 PM
SS69LS1's Avatar
price lowered
Old 05-06-2015, 01:36 PM
SS69LS1's Avatar
to top
Old 05-08-2015, 09:40 PM
SS69LS1's Avatar
still have it..
Old 05-17-2015, 12:07 PM
SS69LS1's Avatar
bump..
Old 05-17-2015, 11:18 PM
TransAmGT's Avatar
Can you run this with stock pistons? Or is flycutting required? Do you have springs, pushrods, trunions, anything else to go with it? Thanks
Old 05-18-2015, 06:28 PM
SS69LS1's Avatar
My stroker has flycut pistons, but I am not sure on ptv w/ stock stroke. I can call comp and see if they could give me a def answer. I have the cam only, I reused everything else.
Old 05-24-2015, 08:23 AM
SS69LS1's Avatar
bump.
Old 05-27-2015, 06:45 AM
SS69LS1's Avatar
still have it..
Old 05-29-2015, 04:50 PM
SS69LS1's Avatar
would trade for smaller cam, something in between 228 & 234 for cathedral port
Old 05-31-2015, 02:23 PM
SS69LS1's Avatar
price lowered again
Quick Reply: FS: comp cam 239/247
