2005 Pontiac GTO 427ci LS3 Full pedders Suspension
Year: 2005
Make: Pontiac
Model: GTO
Price: $23500
Mileage: 48000
Location (State): NY
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
http://s1258.beta.photobucket.com/us...er427/library/
Engine:
LS3 Short Block
427ci Mongillo Monster Forged Stroker LS3 Short Block. 11:1 Compression Callies 58 x 4.100" 4340 Crank
Callies Compstar rods 6.125"
Manley Forged Flat top piston -8cc
Ackerly & child Rings. ( For Nitrous)(Although Nitrous was never even installed) GM L92 CNC ported L92 heads
Comp Push Rods
L76 Port works Ported Intake manifold
L76/L92 Fuel Rails
8 -45# Flow Matched Fuel Injectors
Patriot Dual Valve Spring kit
Yella Terra shaft Mount Roller Rockers
Comp Cams Custom Grind CamShaft 23x/24x, 0.6xx/0.6xx, 11x
SLP Harmonic Balancer
SLP Underdrive pulley
SLP Oil Pump
SLP Double Roller Timing Chain
Mongillo Motors Ported/Polished 90mm Throttle body
SLP 160 degree thermostat
New GM GTO oil pan
DuraBond Cam bearings
Clevite H-series Main bearings
Clevite H-series Rod Bearings
K&N Cold Air Intake
New GM knock sensor
New GM Crank Sensor
New GM coolant Sensor
New GM Oil Pressure Sensor
All New GM Gaskets
NGK Iridium Spark Plugs
JBA Low Resistance Wires
Exhaust
Kooks Long Tube Stainless Steel Headers 1 7/8" x 3"
3" High Flow Catted Mid Pipe
Custom 3" Mandrel bent stainless steel exhaust/bullet style mufflers
Clutch
LS7 Clutch Disc and Pressure Plate
Ram Aluminum FlyWheel
NEW GM GTO Slave Cylinder
New GM GTO Master Cylinder
Solid Stainless Steel Clutch line
Rear
Harrop Differential Cover w/poly bushings
GM GTO only differential fluid
Transmission
Stock T-56
Royal Purple Synthetic Transmission Fluid
GMM RIP Shift one piece billet short throw shifter w/race handle
Suspension
Full Energy suspension bushing kit poly bushings set Graphite impregnated (no Squeaks all bushings replaced)
Pedders Big Bore Rear Shocks
Pedders Front Struts
Pedders Heavy Duty Front Strut Mounts
Pedders Suspension Bolts
Pedders 3mm Raise Rear Drag Springs
Pedders NO DROP front springs
Pedders Front Sway Bar
Pedders Rear Sway bar
Pedders Chrome Moly Sway bar end links
Lovells Front Poly Radius Rod Bushings
Factory Trans and Motor Mounts
New Factory Inner and out tie rod ends
Paint
Rear Valance Painted Body Color
PPG High Metallic Base coat (Factory Quicksilver)
Kemperl Clear Coat (3 coats)
Brand NEW NITTO 555 Tires
2 Spare Factory wheels with used drag radials
Custom Dyno Tune with HP Tuners/VE Computer Tuning
Price - $ 23,500 OBO
