Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
'98 Trans Am Steet/Strip 3010lbs!
Old 08-22-2016, 11:55 PM
Atomic02's Avatar
Default '98 Trans Am Steet/Strip 3010lbs!
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $10000
Mileage: 140
Location (State): TX
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
1998 Trans Am Street/Strip car Clean Title
Wolfe Chromoly 6 point cage simpson 4 point harness's, have the other race seat it's judt not mounted in the pics
Car has been converted over to 2002 specs 0411 pcm and engine harness dash harness and complete interior harness, as well as 02 plastic tank pump and lines
Engine: 347ci '02 LS1 aluminum block, MS3 cam 112 LSA hand ported 799 heads, Ported FAST 90mm Intake, Nick Williams 92mm TB, SLP 85mm maf, K&N FIPK
Trans: Freshly Rebuilt long tail FMVB TH350 with shift kit and ptc 3500 stall 40k cooler Hurst 1/4 stick shifter with brand new hurst cable Aluminum driveshaft
10 bolt rear with richmond 4.10s and a detroit locker
Fuel: Racetronix fuel pump, 42lb FAST injectors, LS3 Fuel Rail, Aeromotive Regulator -6 lines
Tires and wheels: Weld Pro Stars with Brand New M/T front runners and 295/55/15 ET Streets 28's
Brakes: Stock Calipers, EBC Rotors all around with brand new Baer Pads (abs still connected)
Weight reduction: Car weighs 3050 full weight with no driver! converted the car over to crank windows and removed the door bars, no HVAC, No stereo or speakers or amp junk, lightweight steering wheel, no airbags, dash gutted for hvac and and un wanted wiring, no bumper supports just plastic that have been mounted securely, no wipers
Suspension: UMI lca's, custom built sfc's weled in, custom built body mount torque arm, hotchis panhard rod, Eibach springs w BMR helper bag on rh side, no front sway bar but i have a few different ones if you need one
Power adder: Nitrous Outlet 90mm plate kit, new noids, bottle warmer, remote opener, microedge controller, HSW bottle mount, 10lb bottle, set up for 150 shot
VFN 6 inch lift off hood mounted w 7 quick release fasteners
Car went 11.0@124 in 5500ft DA
$10k as is
May consider trades just lmk what you have and thanks for looking
915248649zero
Attached Thumbnails '98 Trans Am Steet/Strip 3010lbs!-14138390_1080683725319595_859501057_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14138988_1080684288652872_2026909548_o.jpg   '98 Trans Am Steet/Strip 3010lbs!-14138558_1080683258652975_1950636950_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14138353_1080683391986295_297757661_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14137793_1080683715319596_1434611551_n.jpg
'98 Trans Am Steet/Strip 3010lbs!-14137711_1080684648652836_1965913441_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14137663_1080684255319542_1527265078_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14123950_1080683991986235_1857678058_o.jpg   '98 Trans Am Steet/Strip 3010lbs!-14111705_1080684245319543_1419480409_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14111660_1080683738652927_619174896_n.jpg
'98 Trans Am Steet/Strip 3010lbs!-14102088_1080683288652972_437601767_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14102009_1080683491986285_291298294_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14101919_1080683245319643_1433666460_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14101586_1080683758652925_1126117764_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14089560_1080683881986246_99567947_n.jpg
'98 Trans Am Steet/Strip 3010lbs!-14088833_1080683838652917_982216600_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14088751_1080683305319637_2030118282_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14081432_1080683575319610_1002012071_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14081197_1080683531986281_1343941158_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14081091_1080684531986181_252957244_n.jpg
'98 Trans Am Steet/Strip 3010lbs!-14081005_1080683721986262_1798854505_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-14055681_1080683435319624_593759526_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-1978810_648533991867906_1446837952_n.jpg   '98 Trans Am Steet/Strip 3010lbs!-1475818_598141830240456_1586610831_n.jpg
Old 08-24-2016, 11:45 AM
Atomic02's Avatar
to the top car will be getting a ported fast 90 and a fast 90mm tb later this week
Old 08-26-2016, 12:50 PM
Atomic02's Avatar
Bump open to trades
Old 08-27-2016, 12:14 PM
01vettezo6's Avatar
Default t/a
So it will pass state emission's ?
Old 08-27-2016, 08:32 PM
Atomic02's Avatar
pm sent
Old 08-27-2016, 08:59 PM
madmike9396's Avatar
How did it do on spray
Old 08-28-2016, 09:51 PM
Atomic02's Avatar
got rained out madmike. did some hits on the street and it pulls hard 25degrees timing up top and no knock
Old 08-29-2016, 03:43 PM
01vettezo6's Avatar
I would like to offer 8,500
Old 08-29-2016, 08:03 PM
Atomic02's Avatar
pm sent
Old 08-30-2016, 11:43 PM
Atomic02's Avatar
bump ill be taking this car to the track this Friday. I can easily swap.in the moser 9 i have
Old 09-02-2016, 09:51 PM
Atomic02's Avatar
to the top
Old 09-07-2016, 08:12 PM
Atomic02's Avatar
bring this to the top
Old 09-12-2016, 11:14 AM
Atomic02's Avatar
price drop. bring it up
Old 09-13-2016, 03:48 PM
avoctane's Avatar
nice ride atomic! glots and he's a good guy so whoever deals with him don't worry he's legit.
Old 09-14-2016, 10:56 AM
Atomic02's Avatar
thanks bro and yeah ill be running it this friday and I'll post the results. ran door to door with a forged 370 single turbo trans am making 600 from a roll on Sunday
Old 09-17-2016, 04:52 PM
Atomic02's Avatar
Car ran 11.40s @ 118mph last night 1.7 60 ft
Was bogging off the line pretty bad. Going to throw it on my dyno this week and go back next Friday.
Also this was @ 6000 ft DA
Old 09-17-2016, 05:42 PM
ragtopz28's Avatar
6000 DA!! I thought we had it bad in S. Florida
Really hoping to get my son's 98 T/A (in sig) that light
Old 09-17-2016, 05:54 PM
Atomic02's Avatar
yeah it's pretty shitty easy 10 second passes as is in some decent elevation, I'll have it dialed in and in the high 10's here by next friday
good luck with your weight reduction project, just start with the basics
Old 09-17-2016, 06:31 PM
ragtopz28's Avatar
We went to the track with it the other day and DA was 3135 and I thought that was ridiculous.
We have removed 274# to date with more to go
Old 09-18-2016, 05:45 PM
Atomic02's Avatar
I have a set of 2002 17 inch WS6 speedlines with decent tires I will include with the car for the street.
It is a little bit of a pain to drive on the street with the fmvb but not really much worse than a 6speed
Quick Reply: '98 Trans Am Steet/Strip 3010lbs!
