Massive Garage Clean-out! FULL LIST OF STOCK AND PERFORMANCE PARTS!
Category: Accessories
Price: $1
Part Fits: 93-02 Pontiac Firebird
Location (State): CT
Item Condition: Used
LS Engine?: Fits LS Engine
I recently did an LQ4 6.0L swap into my 2000 Pontiac Trans Am WS6. The trans am had 72,xxx miles and the donor 6.0L was from a 2004 Yukon with 75,xxx miles. All parts are in very good condition. The car was completed and put on the dyno, but never made it past that point. The block ended up failing due to bearing wash which spun multiple bearings. I no longer have a block to build so everything must go. Almost everything is removed from the car with the exception of a few items. Items are priced accordingly and shipping will be at buyer’s expense, although I would prefer local pickups. This is the initial posting, and pictures will be posted in the following days as I am in the process of moving into my first home.
ALMOST EVERYTHING BELOW IS INTERCHANGEABLE WITH THE 4.8L/5.3L/5.7L/6.0L
Call, Text, or email at (2o3-2o6-Three Four Five Four) or email at cory_lagasse@yahoo.com
2000 PONTIAC FIREBIRD TRANS AM PARTS:
- 2000-2002 CAMARO/FIREBIRD SLP V8 FLOWPAC COLD AIR INTAKE PACKAGE SOLD
- 241 CASTING 5.7L HEADS w/SPRINGS, RETAINERS, VALVES $125.00
- STOCK LS1 CAMSHAFT SOLD
- STOCK LS1 LIFTERS, RODS, ROCKER GUIDE PLATES $40.00
- NEW GM 5.7L HEAD GASKETS SOLD
- LS1 WATERPUMP SOLD
- LS1 TIMING COVER SOLD
2004 GMC YUKON 6.0L PARTS:
- 317 CASTING 6.0L HEADS w/SPRINGS, RETAINERS, VALVES SOLD
- STOCK CAMSHAFT $40.00
- STOCK LIFTERS, RODS $40.00
- STOCK INTAKE MANIFOLD W/FUEL RAILS $50.00
- MASS AIR FLOW $35.00
- EXHAUST MANIFOLDS $35.00
- PLASTIC ENGINE COVERS SOLD
- GM 6.0L COIL PACKS $65.00
- STOCK VALVE COVERS $50.00
HIGH PERFORMANCE PARTS
1. CUSTOM GRIND TICK PERFORMANCE COMP CAM 231/239 .635/.610 112+2 (Shows hot spot from cam bearing, should be good still) SOLD
2. PORTED/POLISHED 243 LS6 HEADS BY WEGNER PERFORMANCE $1600.00
----Matched pair of complete freshly assembled "GM" 243 casting CNC ported small block Chevy cathedral port aluminum cylinder heads. Assembled with titanium 2.0" o.d intake valves and titanium 1.570" o.d. exhaust valves. Includes "PSI" hi-performance valve springs. 64cc combustion chambers. These heads were CNC ported and recently assembled by Wegner Automotive Research in Wisconsin. (One of the most recognized leaders in the hi-performance development and engineering of the LS engines), Wegner heads are ported for performance, not just good looks like other heads that are on the market. In fact some areas of the ports and combustion chambers are left as cast for better flow and performance. These Wegner heads are great for street and street/strip applications. These heads were installed on the build, ran on the dyno, and that was it before the block failed. These heads were crack checked and pressure tested before being assembled. These heads are in Good used condition.
3. MOREL DROP-IN HYDRAULIC ROLLER LIFTERS $170.00
4. COMP CAMS TRUNION KIT, PART #13702-KIT SOLD
5. COMPETITION CAMS 7955-16 5/16" DIAMETER, 7.400" LENGTH HI-TECH PUSHROD SOLD
6. ARP 1343610 HEAD STUD KIT SOLD
7. TRICK FLOW® GM LS ENGINE STEAM LINE PLUMBING KIT 4 CORNER SOLD
8. **COMPLETE** NOS 85MM LS1 WET PLATE KIT (JETS UP TO A 175 SHOT) WITH ALL LINES, FITTINGS, GAUGE, FBODY 4 SWITCH ASHTRAY CONTROLLER, DUAL BLUE LED INTIMIDATOR PURGE LINE KIT, AND FULL 10LB BOTTLE $850.00 (NEVER USED/ONLY INSTALLED)
9. BBK 85MM THROTTLE BODY SOLD
10. DEATSCHWERKS (18U-01-0042-8) 42LB./HR FUEL INJECTORS SOLD
11. MELLING 10296 HIGH VOLUME OIL PUMP (Needs to be cleaned out/rebuilt) $50.00
12. SLP UNDERDRIVE PULLEY SOLD
13. LINGENFELTER LNC-2000 RPM LIMITER TIMING RETARD LAUNCH CONTROLLER SOLD
14. NOS WOT/RPM ACTIVATED WINDOW SWITCH SOLD
15. SPEC CLUTCH SC093 STAGE 3 KIT & SPEC CLUTCH SC75S SPEC STEEL FLYWHEEL SOLD
16. VOLANT DUAL FILTER RAM AIR COLD INTAKE $295.00
17. KOOKS TRUE DUAL STAINLESS STEEL EXHAUST WITH 1 7/8 X 3 RACE HEADERS AND OFF ROAD X-PIPE. ALSO INCLUDES O2 EXTENSIONS/O2 SENSORS, EVERY BAND CLAMP AND HANGER NECESSARY (THIS IS BY FAR THE MOST AMAZING SOUND YOULL GET OUT OF AN FBODY. THERE ARE 2 FLAT SPOTS ON HEADERS FROM PREVIOUS OWNERS WHEELIE STANDS) $2,000.00
18. 4 ORIGINAL CHROME 17X9 WS6 PACKAGE WHEELS $650.00
Almost all of these performance parts above were bolted on brand new for this build and then then removed. They never even saw the road. They are marked a decent amount below what I paid shipped.
Price drop on some performance items!
After the weekend, I sold a few items and edited the list up top... Below are a few items that I felt could go for less money
$1600.00 -----> $1,300.00
$170.00 -----> $150.00
SOLD
SOLD
$295.00 ------> $275.00
KOOKS TRUE DUAL STAINLESS STEEL EXHAUST WITH 1 7/8 X 3 RACE HEADERS AND OFF ROAD X-PIPE. ALSO INCLUDES O2 EXTENSIONS/O2 SENSORS, EVERY BAND CLAMP AND HANGER NECESSARY (THIS IS BY FAR THE MOST AMAZING SOUND YOULL GET OUT OF AN FBODY. THERE ARE 2 FLAT SPOTS ON HEADERS FROM PREVIOUS OWNERS WHEELIE STANDS) $2,000.00 ------> $1,800.00
$650.00 -----> $550.00
THESE PRICES DO NOT INCLUDE SHIPPING OR 3% PAPYPAL FEES!!!
SOLD
SOLD
Holiday Bump!
Just sold a few more items and updated the list at the top! Willing to part with some of these items at an even cheaper price! We will call it a "holiday special"
Just contact me about something you're interested in and we will try to work out a deal!
Holiday weekend bump update!
Sold quite a bit over the holiday weekend guys! Here is the most up to date list of what is still available! Feel free to make some fair offers and I'll see what i can do!
853 CASTING 5.7L HEADS w/SPRINGS, RETAINERS, VALVES (Exact same as 241 heads) $125.00
**COMPLETE** NOS 85MM LS1 WET PLATE KIT (JETS UP TO A 175 SHOT) WITH ALL LINES, FITTINGS, PRESSURE GAUGE, FBODY 4 SWITCH ASHTRAY CONTROLLER, DUAL BLUE LED INTIMIDATOR PURGE LINE KIT WITH CUSTOM BRACKETS FOR MOUNTING BEHIND HONEYCOMB RAM-AIR GRILLS, AND FULL 10LB BOTTLE, AND SPARE TIRE MOUNTING BRACKET FOR FULL CONCEALMENT $850.00 (NEVER USED/ONLY INSTALLED)
$295.00 ------> $275.00 -------> $225
RACETRONIX FUEL PUMP KIT FOR 1998-2002 F-BODYS (Installed and used for about 2 weeks before the engine went bad) $175.00
--The FPA-001B is recommended for factory HP upgrades to 600HP @ 58PSI using the factory lines and fuel pressure regulator. HP support may vary for N/A or F/I motors. Please factor in a 20-25% safety margin between what your motor needs and what your fuel system can supply. Our FPWK-017W wiring kit is highly recommended to maximize performance. Please contact your local Racetronix dealer to discuss your fuel requirements.
--853 Heads are pending sale for this weekend
--243 Heads are pending sale for this weekend
--Morel Lifters are pending sale for this weekend
--WS6 Wheels are pending sale for this weekend.
All remaining items will be negotiable on pricing!
That includes the following:
--Kooks True Dual Exhaust
--NOS LS1/LS6 Wet plate kit
--Racetronix Fuel Pump Kit
--Volant CAI
--Miscellaneous Parts
--Volant CAI
Price drop on all items!
PRICES HAVE BEEN REDUCED ON EVERYTHING AGAIN!!! NO ROOM AT THE NEW HOUSE SO THIS STUFF HAS TO GO!!!
- 853 CASTING 5.7L HEADS w/SPRINGS, RETAINERS, VALVES $110.00
- STOCK LS1 LIFTERS, RODS, ROCKER GUIDE PLATES $30.00
- STOCK CAMSHAFT $30.00
- STOCK LIFTERS, RODS $30.00
- STOCK INTAKE MANIFOLD W/FUEL RAILS $40.00
- MASS AIR FLOW $25.00
- EXHAUST MANIFOLDS $30.00
- GM 6.0L COIL PACKS $45.00
- STOCK VALVE COVERS $40.00
**COMPLETE** NOS 85MM LS1 WET PLATE KIT (5 SETS OF JETS UP TO A 175 SHOT) WITH ALL LINES, FITTINGS, PRESSURE GAUGE, FBODY 4 SWITCH ASHTRAY CONTROLLER, DUAL BLUE LED INTIMIDATOR PURGE LINE KIT WITH CUSTOM BRACKETS FOR MOUNTING BEHIND HONEYCOMB RAM-AIR GRILLS, FULL 10LB BOTTLE, AND SPARE TIRE MOUNTING BRACKET FOR FULL CONCEALMENT $700.00 (NEVER USED/ONLY INSTALLED)
MELLING 10296 HIGH VOLUME OIL PUMP (Needs to be cleaned out/rebuilt) $30.00
$200.00
KOOKS TRUE DUAL STAINLESS STEEL EXHAUST WITH 1 7/8 X 3 RACE HEADERS AND OFF ROAD X-PIPE. ALSO INCLUDES O2 EXTENSIONS/O2 SENSORS, EVERY BAND CLAMP AND HANGER NECESSARY (THIS IS BY FAR THE MOST AMAZING SOUND YOULL GET OUT OF AN FBODY. THERE ARE 2 FLAT SPOTS ON HEADERS FROM PREVIOUS OWNERS WHEELIE STANDS) $1,100.00
$500.00
$1,300.00
$120.00
RACETRONIX FUEL PUMP KIT FOR 1998-2002 F-BODYS (Installed and used for about 2 weeks before the engine went bad) $165.00
$200.00
$500.00
$1,300.00
$120.00
Full kooks exhaust and lifters sold!!!
THE FULL KOOKS EXHAUST AND MOREL LIFTERS HAVE BEEN SOLD!!! PRICES HAVE BEEN REDUCED ON EVERYTHING!!! BELOW IS THE UPDATED LIST.
$200.00
$500.00
$1,300.00
$200.00
$500.00
$1,300.00
