huge list of parts
huge list of parts
Category: Accessories
Price: $1
Part Fits: 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
need zip code for shipping
Interior Pieces******************
2002 z28 air bags with 100 miles 95 new
shift plate (1st on shift plate) 5
Spare tire wrench 10
1999 v6 dash cluster 70
2002 ls1 bezel with 2000 miles 150
Air bag modules 20
1 near new bose speaker 50
Seat belts 95-97 30 each
GM stereo amps monsoon amp 30
cover below steering wheel 93-96 0r 97-02 25 gray
insuators under dash driver or pass 10
Body control mod. from 2002 z28
tan ************************************************** ********
rear spare tire area cover 10
tan oem floor mats used 20
new tan floor mats not oem but brand new 25
speaker covers 8
93-96 fuse cover 15
97-02 fuse cover 20
97-02 vent bezels 8
1993-96 vents 8
consel shifter bezel with shifter id 93-96 30
tape holder 93-96 5
consel filler 10
T-top body seals 80
T-top conversion parts ask
Convertible body seals 3 pcs low miles $150
Convertible pump $150
Convertuble top arms $200 (dealer 450 each)
Other various convertible pieces ask
v6 drive by wire pedals 1999 50
v6 drive by wire brake pedal single 50
tan cargo cover 25
air bags 93-02 50 ea
air bag modules 15
Engine:
lt1 fuel lines 90
HVAC controllers w/ ***** 25
LT1 valve covers 25
LT1 oil cooler mount 30
LS1 stock cam from 2001 vette w/ springs, locks 150
Evap system for fuel tank, located in drivers 1/4 near gas cap. 15
Evap lines to gas tank 20
LS1 valve covers 1 need repair 30
LT1 opti 2 timing cover 50 not crank sensor type
lt1Power steering pump 75
LT1 coil 15
LT1 idler pulley 15
LT1 head coolant tubing 25
LT1 alternator 75
LT1 guild plates spider 20
LT1 Oil pan 40
Lt1 Bare intake 50
Lt1 Bare throttle 25
LT1 Water pump drive gear with bearing 30
LT1 Water pump drive coupler 30
LT1 new lt1 oil pan 65
LT1 oil level sensor 25
LT1 piston and rods 20 each
lots of misc lt1 parts just ask
LT1 t56 clutch , pressure plate used 50
LS1 valley cover 45
LT1 evap silnoid 15
LT1 egr 15
Windshield washer res. 25
Windshield washer pump 10
Fueling:LT1
Gas tank bare 20
Gas tank straps 5
Gas cap door 10
Gas cap 5
Fuel pump 45
lt1 valve covers
lt1 alt
ls1 gas lines
lt1 gas lines
lt1 fuel pump used
idler pulley lt1
Braking:
LT1 front and rear rotors 10 each
master cylinder 35
Brake booster 30
torque arm mount 25
shifter lock out a4 20
many lt1 brake related parts
Exhaust:
new ls1 y pipe 125
exhaust hangers rear or center 25 ea
Wheels/Tires:
Drivetrain and Misc.:
Most nuts bolts for whole car
lt1 rack pinion 80
Rear lower control arms 25 each
track bar 25
LT1 drive shaft 40
heater core 20
heater blower 15
ac coil 20
auto trans tunnel brace 5
spare tire wrench 10
sway bar mounts upper 6 EA
sway bar lower halfs 6 EA
steering u joint plastic covers 10
front spring and struts low miles 120
rear spring isolator 20
stock lca 25 ea
Exterior Body Pieces:
rear bumper impact plastic
30mm front sway bar
20mm rear sway bar
radiator air delfectors
rear berger panel
rs lower valance rear
1993-97 front bumper impact plastic/steel bumper
Lambo door kit for passenger side door 95
Chassis heat shields
Door hinges
LT1 Front impact plastic with metal support
Steering u-joint plastic covers
Head light mounting bar
nuts bolts from few part outs most 93-97 some 2001
wiper motor 35
wiper arms 30 pair
berger rear panel 60
hood struts 25 pr
hood hinges 15 each
hatch struts 30 pr
passenger door 93-92 $60 with glass
set Chassis heat shields $25
Black roof bar for t-top cars $40
lt1 Front bumper impact plastic with metal support $25
Steering u-joint plastic covers $10
lt1 Head light mounting bar $45
windshield washer res 20
gas door with plastic 10
chassis heat shields 25 for set
tan rear interior spare plastic screw 1
a/c fill caps 3
rad cap 2
seat belt bolts 2 each
lt1 thermo neck 10
interior clothes hook 2
door latches 5
lt1 throttle bracket 15
hood bumpers 2 ea
washer fluid cap 3
ac expantion valve 6
dr or pass window felt guild 8 ea
door striker 5
seat belt screw cover 2
lt1 oil cap 5
brake pedal switches 8ea
lt1 valve cover pvc grommit 2
batter hold down clamp 5
rad bottom iso rubber 5
new fuel filter clamp 5
seat nut cover 1
hood strut ends 2
rs grd fx mounts 8 ea
air cleaner clamps s.s. Common lost 8
t top reciver 10 ea
body rubber plugs 2
coin holer 4
fuel line locks 2
consel insert holder 5
spare jack t bolt 5
tail light t nuts
spare tire large hold down washer 5
heater ***** 3 each
ashtray 5
various push type retaines for car 1ea
misc body emblems 10ea
hood isualtion buttons 2ea
rad hose tee 10
body u clips 2
horn button switches 5ea
head light adjuster 5 ea
