Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans
Old 07-21-2016, 09:44 PM
kwik_ls1's Avatar
Default 2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans
Year: 2000
Make: Pontiac
Model: Firebird
Price: $18000
Mileage: 78000
Location (State): MI
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Hello, so here is the deal. I bought this car from High Impact who is a fellow member on this forum. I bought this car on 7/18 Monday and had it transported from Florida to Michigan and it arrived on wednesday. I was all happy because there is a big cruise here this weekend so I planned on taking my 5 year old and 2 year old out to it in the car. Well my wife put a stop to it because there is a roll cage in the car so now I am flipping pissed. Anyways, so now I have nothing else left to do but sell it and search for something else. According to Mark, the car made 872rwhp at 19lbs on the old motor. The new motor I am sure will do much better and is good up to 23lbs. Since the motor and trans are not broke in because they only have 300 miles on them, I have not pushed it and have only drove it 5 miles to the gas station and back. The car has a ton of power and is probably one of the best built street cars out. But the motor and trans are brand spanking new because the old motor was an aluminum block and this is an iron block. I paid $21500 for the car plus transportation of $650. I just want to get $18000 for the car so I only lose a little. Worse comes to worse I will part it out but if someone wants a 1000rwhp street car that is built very well, this is the car. I do have the back seats and belts that will need to be put back in the car. Feel free to text me since that is the best way to get hold of me at 313-790-5592. Any questions, please let me know. Thanks.
Tony
Link for original sale ad.
https://ls1tech.com/forums/vehicle-c...turbo-car.html
Use this link for videos.
http://m.facebook.com/highimpactformula
Bought Car from High Impact on LS1Tech on 7/18/16
Engine: Forged 347 Iron Block – 300 Miles on Motor
• Callies Compustar 6.125 Rods w/ ARP2000
Stock Polished Crank (Balanced Rotating Assembly)
• Wiseco Coated Pistons / Rings 3.903
Total seal rings with top steel rings, gapped.027/.028
King coated rod and main bearings
ARP main stud kit
Improved Racing Baffle with stock F-body oil pan
• Trick Flow 215CC Heads w/ LS9 Head Gaskets
• LS6 Intake
• LJMS Spec’d Cam Motion Solid Roller Turbo Cam 233/239 .637/.613 115+
• Jessel Adjustable Shaft Rockers
• Trend Pushrods from LJMS
• Morel Warhawk Pro Link Bar Lifters
• Mast Valve Covers w/ Custom Coil Brackets & Truck Coils
• Relocated Alternator to Upper Left side of Motor
• Power Steering
• Mighty Mouse Catch Can
Polished Coolant Overflow Can
Transmission: Jakes Level III 4L80 – 300 Miles on Trans & Converter
• Built by Robert Godfrey
• D1 Trans Brake
• Billet Input 32T Output
• 36 Element Sprag
• Billet Front Hub and Pressure Plate
• Rossler Deep Aluminum Pan
• 1350 Yokes and Solid Joints
• Chromoly Crossmember
• PTC Spec’d 9.5 In Non-Lockup Converter
• B&M Ratchet Shifter with Hurst Pistol Grip
BMR chromoly crossmember w/ Polyurethane Mount
TCI SFI flywheel
Suspension & Rear
• Moser 12 Bolt Rear w/ Big 9 In Ends, 3.42 Gear, Spool, Trick Flow Rear Support Cover, Relocation Brackets, 1350 Yoke
• QA1 Front and Rear Adjustables
• LG G2 Adjustable Lower Control Arms
• LG G2 Short Torque Arm
LG G2 Adjustable Panhard Rod
• UMI Three Point Sub Frame Connectors
• UMI Ultimate Adjustable Drag Bar
• PA Racing Turbo K-Member w/ Solid Mounts
• Midwest Chassis Bumper Support
• Midwest Chassis 8 Point Roll Cage
Wheels & Tires
• Weld RTS Wheels
o Front 15x4.5
o Rear 15x10 w/ MT Pro Radials
Fuel System
• Lonnies 340 Stainless E85 Double Pumper Kit w/ -8/-6 PTFE Lines & Fittings (from take to engine)
• Aeromotive Boost Reference Regulator
• Nasty Fuel Rails
• 105lb Deachtswerks Ethanol Compatible Injectors
• Stock Tank
• AFX Wide Band
Turbo Kit
• Forced Inductions Borg Warner S480 Billet Wheel 1.1, 92mm T4
• Truck Manifold Kit w/ Custom front mount crossover with dual waste gate feeds, heat wrapped
• 4 In Bumper Exit Downpipe w/ Dynomax Bullet Muffler
• 60mm JGS Wastegate Fed From Both Sides of Hotside (very efficient)
• 60mm JGS Blow Off Valve
• Treadstone 4.5 In Intercooler w/ 3 In Aluminum Cold Side Piping
• Turbo Blanket and Hot Side DEI Wrapped
• Leash Pulse Boost Controller w/ Bump Box
Huron Speed alternator relocation brackets
Oil feed line (-4an) and drain line (-12an) and fittings
Other:
• Battery Relocation to Spare Tire Well w/ Flaming River Battery Cutoff
• MSD 2 Step
• Quick Release Steering Wheel and Hub
• Slotted Rotors and Pads
• Factory Ram Air Hood
• Tinted Tail Lights and Marker Lights
• Lloyds Floor Mats
• Stock Interior – No AC or Heat
• Sony Headunit w/ JL Speakers & Crossovers (Radio needs to be wired to power currently)
• Tuned by Hoosier Street Cars on E85
• 55-241 Griffin Radiator w/ Modified Stock Fans and Trans Cooler
• SJM Line Lock w/ Adjustable Proportioning Valve
• Have Rear Seats and Belts to go Back in the Car
Midwest Chassis Limiters
Minor Issues w/ Car
• Dash Pad Needs Replaced
• Tear in Bottom of Driver Seat
• Car Could Use a Good Buff and Front End Has Normal Rock Chips (Original Paint)
• Radio Needs to Be Wired
I may be open to trade on a Camaro SS with full suspension mods plus cash in Black, Silver or Pewter. Also I prefer an auto car. Also open to G Bodies or a Chevelle or Nova with the right mods or anything with a back seat. No caged cars.
Attached Thumbnails 2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans-fb1.png   2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans-fb2.png   2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans-fb3.png   2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans-fb4.png   2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans-fb5.png
2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans-fb6.png
Old 07-22-2016, 01:24 AM
99f1's Avatar
Old 07-22-2016, 08:45 AM
hireman's Avatar
subscribed...something seems odd here. Buy a car and turn around and put it for sale 2 or 3 days later????
Old 07-22-2016, 08:57 AM
kwik_ls1's Avatar
Well nothing I can do. The wife doesn't want the kids in a car with a cage. I have bought 14 F Bodies since I have been on this site back in the early 2000's. Nothing wrong with the car but I am not cutting the cage out. I will just need to find a car of this caliber with no cage. If I can't sell it, I will part it out. No qualms there. Out of the 14 f bodies I have owned, I ended up parting out 5 of them so either it will sell or it will get parted. Talk to the guy who built the car. I attached his original sales thread on the car. There is nothing wrong with it. Just the cage has to go or the car. Easier to sell the car than it is to spend all of that time to take the cage out. My kids are 5 and 2. So they are young still. If they were older then it wouldn't be a big deal.
Old 07-22-2016, 10:06 AM
hireman's Avatar
looks like a quality build...Id cut the cage out, but thats just me
Old 07-22-2016, 11:40 AM
BODUKE's Avatar
You were going to the Telegraph cruise I take it.
Old 07-22-2016, 02:11 PM
kwik_ls1's Avatar
I was going to take it but can't take since I will have my kids. I may possibly drive it out there if I can get a sitter for my kids.
Old 07-22-2016, 11:12 PM
kwik_ls1's Avatar
Updated the thread with more of the mods. Also open to some trades, preferably a Camaro SS with full suspension mods plus cash preferably in Black, Silver or Pewter. Also open to G bodies with the right mods or a car with 4 seats. No caged cars.
Old 07-23-2016, 10:25 PM
kwik_ls1's Avatar
Bump for the night....
Old 07-25-2016, 07:06 PM
kwik_ls1's Avatar
Bump for today.....this may be parted out if i dont have a buyer or trade soon....
Old 07-25-2016, 08:19 PM
98Camarod's Avatar
Why not just cut out the cross bar on the main hoop? That's the only thing that would affect the kids in the back seat. Nice car, free bump!
Old 07-25-2016, 08:35 PM
kwik_ls1's Avatar
I would but my wife doesnt want the kids in the car with the cage at all. So its all good. Take a step back to take 2 steps forward.
Old 07-26-2016, 07:32 PM
kwik_ls1's Avatar
May look into parting this thing out if no trades or cash buyers come along. But before i part it out i would have to have buyers lined up for the engine, trans, turbo kit and rolling chassis. Just a thought. I have done it before and have no problems doing it again, lol....
Old 07-26-2016, 08:11 PM
tom j's Avatar
Modify the cage and stand up to the wife
Old 07-26-2016, 09:59 PM
kwik_ls1's Avatar
I could do that. Lol but with the limited amount of time i have to make it perfectly cut out i dont have the time. Much easier to just start out with a non cage car lol....
Old 07-28-2016, 11:58 PM
kwik_ls1's Avatar
Ttt.........
Old 07-31-2016, 11:22 PM
BlackDuk98's Avatar
Pardon my French but that's some fucked up **** right there.
I understand the no time part, I would suggest having a shop cut it out nicely. The time it takes to deal with phone calls, emails, people looking at it, title transfer, you can have the cage out and a car that your wife will approve of. If you are going to part it out, how will you have time to tear it down? The cage will take very little time to cut out.
Whatever you choose, I wish you luck
-Mark jr.
Old 08-02-2016, 05:42 PM
kwik_ls1's Avatar
-Mark jr.
I will not end up parting this out but i am going to just sell this outright. I am going to drop the price to $21,000 and see where that gets me. I have another car on hold after this sells.
Old 08-05-2016, 02:29 PM
kwik_ls1's Avatar
ttt.....
Old 08-08-2016, 10:28 PM
kwik_ls1's Avatar
Ttt.....
Quick Reply: 2000 Pontiac Formula Firebird Turbo Car - Brand New Forged Engine & 4L80 Trans
