Forged 347" LS1- Complete from Fuel Rails to Pan! Available to see running in car!
Tenured Member
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Up for sale is a 347" Ls1 motor that we built and had AES machine.
Motor has exactly 1,740 miles on it since freshened up. Runs perfect, makes great power, zero issues. Just parting some things out on the car.
Idle clip:
Here are some pics of when motor went together:
Here are some details:
-3.905" CP Pistons w/-3cc valve reliefs
-6.125" Eagle H-Beam Rod
-Factory polished crank
-Steel ring set gapped for boost/nitrous
-Ported 853 heads (Heads flowed great, just need to find flow sheet)
-Brian Tooley spring kit
-ARP Head Bolts
-MLS Head Gaskets
-Texas Speed Magic Stick 3 237/242 .603"/.609" 112LSA Cam
-GM LS1 lifters
-Chromoly pushrods
-TSP oil pump
-Billet timing set
-LS6 Intake
-Ported & Polished OEM throttle body
-36lb injectors
-Factory Fuel Rail
Motor comes complete from fuel rails to oil pan minus sensors. Motor is still in car. You can come see it run before it gets pulled.
Motor made 408RWHP & 405RWTQ on Mustang Dyno all through a 4L60E and 9". Dyno'd on 1/26/15
I have the Speed Density tune for the car that I can send you or flash your pcm.
Installation is available, or local delivery available. I will consider shipping it as well.
$4000 for everything.
PM me or call/text me @ 847-420-31FiveOne
