S91mm OFI Tubular Header COMPLETE turbo kit. KEEPS A/C
Category: Accessories
Price: $4700
Location (State): UT
Item Condition: Used
LS Engine?: Fits LS Engine
Selling my complete Turbo kit from my car that I've finally decided to part ways with. This is a T6 turbo kit capable of 1600hp and it retains A/C if you desire.
Turbo setup-
OFI T6 Turbo kit (turbular headers)
TIal 44mm wastegate
Tial 50mm BOV
Borgwarner S491 (91mm/121mm comp wheel, 96mm/89mm turbine wheel. 5" inlet, 3.5" outlet comp cover and 5" downpipe on the turbine side with T6 flange 1.32 a/r) This has the RACE cover. Rated at 165lbs per minute (10hp roughly per lb.)
This kit was coated by HPC here in utah when they had a location here. The kit has been installed and removed a few times since then and the coating has a few chips now.
The hotside is coated with ceramic coating, and the cold side just a polished look silver high temp coating. The charge pipe going to the intake was polished. I'm including everything.
Dual Spal fans
Radiator/hoses/tbolt clamps for hoses (worm gear clamps were replaced in pictures)
tubular headers (ceramic coated)
Crossover (ceramic coated)
Down pipe, 5" that goes down to 4". This runs all the way behind the trans crossmember. (ceramic coated til the firewall, then it has a high temp black coating)
Cold side pipes (high temp polish looking coating)
Intercooler
Oil lines
Expansion tank for the radiator
This kit although being older is one of the best kits ever made for the f-body platform. It has literally maybe 3 hours run time on it ever. I purchased everything brand new and worked out all the quirks with the kit. It is ready to bolt on and make havoc.
This kit has been modified to work with the BMR TURBO k-member. It is suppose to fit stock k-member as well. No relocating of anything with this kit except for replacing your radiator with the included radiator/fans.
I have never pushed any power through this setup either. Never got either engine I ran with it tuned in as I had other issues pop up with both...
PM me with interest. Located in SLC, Utah
$4700 OBO
Bump this up. I am open to REASONABLE offers! If there are other comparable kits, please link me to them so I know a basis as to where to price this. I am in this kit over 6 grand.
