Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
FS: LME LSX 427 Longblock
Old 08-26-2014, 07:59 AM
cammedc6's Avatar
Default FS: LME LSX 427 Longblock
Price: $15000
Location (State): TX
Item Condition: Brand New
LS Engine?: Fits LS Engine
Selling my LME LSX 427 6 bolt ½” stud lonblock. Motor is still being built and should be off the engine dyno in 2 weeks ready for pickup by the buyer or shipped to the buyer. Only run time on this motor will be the break in and engine dyno at LME once they are done assembling the motor. This motor will save you 4-6 months of wait time on building a motor as well as $$$$ since I’ll be taking a hit just to move it. Only reason for selling is I’m not interested in my project car/build anymore. Time to move on. My loss, your gain. Below are the details of the motor. Would like to sell it as a whole but if someone is interested in the shortblock I may already have a buyer for the heads and rockers. I’ll get pics from LME once motor is complete or you can run by their shop to take a look at it. PM for LME invoice and build sheet if interested.
I have over $22k in the motor
Selling firm for $15,000 plus Paypal fees and shipping
Wet sump
C6 Corvette oil pan and windage
Valley, front, and rear covers
Katech black krinkle valve covers, coil relocation, and longer MSD spark plug wires
ATI pulley
1400+ RWHP 11.0:1 compression (-6cc pistons and 67cc heads)------58X Balance, Blueprint & Assemble Shortblock: fully deburr block, line hone block w/ ARP main studs, deck block to desired deck height w/ BHJ deck true fixture, bore block on 3 axis CNC, hone block w/ torque plates, balance crankshaft to 1/4 oz. in. tolerance, hang pistons on rods, check bearing clearances, file fit rings, assemble shortblock.
Disassemble heads, chamber volume measured & adjusted for compression, valve job lapped in, valve job hand blended to ports, guide clearance checked & adjusted for application, spring pressures adjusted for camshaft
Assemble Complete Longblock & DYNO TEST
ENGINE: degree cam, check piston to valve clearance, adjust valve train geometry & lifter pre load, install oil pump & heads, Modify & Install Covers
GM Bow Tie LSX race block. Features: priority main oiling, billet main caps, increased cylinder wall & deck thickness, 6 bolts per cylinder(for added improved head gasket sealing. Block comes w/cam plate, rear cover, all plugs & dowel pins
Callies Dragon Slayer 4340 forged 4.0" stroke crankshaft w/Indexed & Trued Journals
Oliver Billet Speed Way I Beam Rods w/A1 XTF Bolts (proven & over 1800 RWHP)
Wiseco/LME Custom Forged Pistons w/Upgraded Heavy Wall (.200")Tool Steel Wrist Pins & Anti Friction Coating On Skirts: Includes lateral Gas Ports & Double Pin Oilers.
Total Seal stainless chrome top, napier 2nd., 3mm HT oil Rings
Clevite MS 2199 H mains, Clevite CB 663 H rods, Dura Bond CH-23 cam bearings
ARP Pro Series 12pt. main stud kit
Cam Motion custom LS1 camshaft
Rollmaster double roller timing set w/ torrington bearing and nitrited gears 4X
Cometic MLS 6 bolt head haskets
Manley 3/8" x 7.xxx x .120" Wall
Melling 10296 coated high volume/ high pressure oil pump, ported
Lunati high RPM link bar lifters (Part # LUN 72437) (Barely used from my previous motor. Nothing wrong with them. Checked out by LME)
Mast 285 LS7 large bore heads (Barely used from my previous motor. Nothing wrong with them. Checked out by LME)
Mast titanium exhaust valves (Barely used from my previous motor. Nothing wrong with them. Checked out by LME)
Inconell Exhaust Valves (New. Upgraded by LME)
LME dual valve spring kit: dual springs good to .675" lift, titanium retainers, locks, locators, Viton valve seals (New. Upgraded by LME)
Machine block for 1/2" head studs
ARP 1/2 LS1 head studs
Crower Pro series Shaft Mounted Adjustible Rockers Arms
GM LS2 front cover w/ cam sensor, gasket, seal, and bolts
Pics added
Old 08-26-2014, 09:45 AM
BLWN1's Avatar
Nice..
Old 08-27-2014, 07:54 AM
cammedc6's Avatar
.bump.
Old 08-28-2014, 07:41 AM
cammedc6's Avatar
.ttt.
Old 08-29-2014, 01:15 PM
cammedc6's Avatar
pics added
Old 08-29-2014, 11:40 PM
CAMSTER's Avatar
Few question, cam specs, build for boost? piston rings end gap and lifters part number thanks...
Old 08-30-2014, 09:10 AM
cammedc6's Avatar
Boost. I'll have to get the final build sheet from lme on Tuesday and I'll PM it to you.
Old 08-31-2014, 10:16 AM
cammedc6's Avatar
ttt
Old 08-31-2014, 02:47 PM
02SSLE's Avatar
Bump.
Old 09-01-2014, 09:48 AM
cammedc6's Avatar
labor day bump
Old 09-01-2014, 10:36 AM
SmokedOutZ28's Avatar
Pm a price for the short block. I've been talking to LME last week about building a very similar setup.
Old 09-02-2014, 09:32 AM
cammedc6's Avatar
.ttt.
Old 09-02-2014, 11:14 PM
Trackman's Avatar
When is the motor going to be on the dyno? What is the expected hp numbers?
Was it built for boost?
Old 09-03-2014, 05:43 AM
cammedc6's Avatar
They said this week. Built for boost. Should make around 650 on engine dyno. Once in car I was planning to make 1000 on low boost and 1500 on high boost.
Old 09-03-2014, 03:38 PM
thenate125's Avatar
Payment sent cant wait to get this in my car thank you Cammedc6 been nice dealing with you
Old 09-03-2014, 07:51 PM
cammedc6's Avatar
No problem. Been a pleasure. I'll let LME you are the new owner of the longblock so they can arrange shipping with you.
Quick Reply: FS: LME LSX 427 Longblock
