Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85
Old 07-14-2014, 08:43 PM
TexasTTWS6's Avatar
Arrow 01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $20000
Mileage: 86000
Location (State): TX
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Kicking around the idea of selling the car to invest and pay off some debt. Car doesn't get driven as much as it should. Sits in the garage most of the time, I rarely have time for it anymore with everything else going on in my life. If it doesn't sell no biggie.
I will list the important info on the car. I'm honest about everything. The only bad things I can think of is a small dent on the rear quarter panel on the drivers side. Heat works, but A/C blows hot. Previous owner said it needs a new compressor, I never tried to fix it as I don't use it anyways. ABS light is on also. Dont know problem. ABS does work though. E-Brake doesn't work.
Interior door panels are flawless, no cracks (if you know anything about these cars you'd know that it's hard to find one without cracks). No bubbling on the top of the car either.
The car runs and drives great. It's a blast to drive. Turbos are loud as hell even at idle. Gets looks everywhere. I bought the car in August last year. I've driven it to work and back 40 minutes each way with no hiccups. Never heats up, even in stop & go traffic in 100+ degree weather.
The car has 85K miles on it - the turbo kit, built motor, etc. all have 9K miles...
Car is tuned on 16.5lbs on e85, haven't gotten any numbers on it yet. My guess is around 720whp. I can have it dyno'd if need be.
The black exterior is damn near flawless other than the small dent. Interior is perfect as well, all untouched.. Car still has heat, and A/C, back seats etc...
Asking $20K, clean title in hand.
Serious enquiries only. Please don't waste my time. No joy rides. No tire kickers.
Email: ericbuffs55 AT gmail DOT com or Text me anytime at 8O6-23.1=62.34
Modifications
---Engine---
• 9.0:1 CR
• Stock aluminum block LS1 (5.7L), bored .010 over (348 ci)
• Polished crank and fully balanced rotating assembly
• -16cc Mahle forged pistons
• Eagle 4340 forged H-beam connecting rods w/ ARP L19 bolts
• Clevite bearings throughout
• Ported and polished 5.3 heads (heads/valves have 3000 miles)
• ARP head studs
• LS9 head gaskets
• Comp Cams 220/224 .564/.568 115 lsa, custom turbo grind cam
• LS2 timing chain
• LS6 ported oil pump
• Edelbrock Pro Flo Intake
• 90mm Throttle body
• Patriot Performance Gold dual springs, with titanium locks and retainers
• LS7 lifters
• NGK BR7EF plugs
• MSD wires with coil relocation under radiator
• Black painted valve covers with welded on -12 AN bungs
• Custom catch can setup
---Turbo Kit---
• 58mm Precision turbos, T4 .81 AR exhaust housings.
• Custom built, thick walled stainless steel log manifolds
• 3” Stainless steel downpipes, merged into 4” stainless exhaust, then dumped before the axle
• Custom aluminum coldside - 2" from turbos to intercooler - 4" from intercooler to TB
• Polished 27" x 12.5" x 3.5" intercooler
• (2) 38mm Tial wastegates
• (2) 50mm Tial Blow-off valves
---Fuel System---
• Fuel system good for 1100 whp on E85
• Custom fabbed 25 gallon fuel cell by DBRODS Speed & Chassis
• 90 ohm summit fuel sending unit
• -10 AN black braided Earls nylon feed line
• -8 AN black braided Earls nylon return line
• Injector Dynamics ID2000 injectors
• Aeromotive 13110 - Pro-Series EFI Regulator
• All black Earls fittings
• Magnafuel 4303 Fuel Pump
• Aeromotive billet pre/post fuel filters
---Suspension---
• Custom welded "in-floor” subframe connectors (2”x4”)
• BMR tubular K-member
• BMR tubular upper A arms
• BMR tubular lower A arms
• BMR tubular rear lower control arms
• BMR tubular panhard bar
• BMR rear lowering springs
• BMR adjustable torque arm
• BMR tubular Torque Arm Relocation Crossmember
• Strange single adjustable coilovers in front with 300lb springs
• Strange single adjustable shocks in rear
• Polyurethane motor mounts
• Polyurethane trans mount
---Drivetrain---
• Stage 2 Built T56 6-speed
• RPS Twin Disc cluth (Entire clutch assembly with flywheel weighs 27lbs).
• MGW Shifter with custom cobra ****
• 3.5" aluminum driveshaft
• Moser 12-bolt rear end
• Detroit True-trac differential w/ 3.08 gears
---Wheels/Tires---
Fikse Aros - 17x9.5 fronts | 17x11 rears
M&H 325/45/17 DRs in rear
Nitto NT555 275/40/17 fronts
---Brakes---
Drilled/slotted rotors
Ceramic pads
---Miscellaneous---
• Full A/C, heater, etc. all stock accessories are kept in stock location
• A-pillar 3 gauge pod – wideband o2 (a/f), fuel (psi), boost/vacuum (psi/hg) and eboost2 electronic boost controller in the left vent
• Original US Exotics Superhawk fiberglass hood (1 of 5 made)
• Custom 3-bar speed density tune on e85
• Battery reloation to the rear
• Custom mesh license plate cover
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-18hiclv.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-5lxqmwe.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-v1nnn8d.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-4zkp9ac.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-as608kx.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-jiciutx.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-3ou34dr.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-ytwk9wi.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-sunocap.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-agxchbn.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-10yktu2.jpg
Vs some 10 second HCI C6s on 16lbs
Some in car footage when I was still working on the tune:
Old 07-15-2014, 11:55 AM
TexasTTWS6's Avatar
Bump, also forgot to add that I can include hp tuners to tune the car as well as a 3.42 gear set with a rebuild kit.
Old 07-15-2014, 05:02 PM
TexasTTWS6's Avatar
Some more pics...
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-ftot5zk.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-gitp05b.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-b8jcgls.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-a2qf5nq.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-f8uyjri.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-7w1hcqo.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-40dwasb.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-y5equ9l.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-rp5a82q.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-wqsupzx.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-5sltucf.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-jnksvpn.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-0yivly5.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-pdrbm8h.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-cqpjs88.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-7etqb7s.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-w7tx6a9.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-5q2j0s3.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-vv7dthp.jpg
01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85-gcd91tb.jpg
Old 07-15-2014, 05:24 PM
BudRacing's Avatar
A steal at that price for a running/driving badass car!
Old 07-15-2014, 10:09 PM
Joey D's Avatar
Bump great car/seller
Old 07-16-2014, 01:56 AM
JDEP162's Avatar
bump for a badass car, love the grocery getter picture.
Old 07-17-2014, 07:38 AM
TexasTTWS6's Avatar
Thanks guys! Bump!
Old 07-18-2014, 12:58 PM
TexasTTWS6's Avatar
Bump!!!
Old 07-19-2014, 12:03 AM
99Custom's Avatar
Oh man I absolutely love it!!! Honestly wish I could afford it right now.
Old 07-20-2014, 09:58 AM
miahjera04's Avatar
this still available? where in tx u located?
Old 07-20-2014, 11:58 AM
TexasTTWS6's Avatar
Some footage from last night vs a 800whp TT viper... still on 16lbs.
Yes it is, Austin TX.
Old 07-21-2014, 12:23 AM
miahjera04's Avatar
ok thanks
Old 07-21-2014, 11:59 AM
steveo346's Avatar
Eric, you created a new user name?
Old 07-21-2014, 02:31 PM
AnotherWs6's Avatar
Lol, the fox body. Fng thing just disappeared.
Old 07-22-2014, 08:56 PM
TexasTTWS6's Avatar
Bump.
Cool vid Texas Throttle did:
Old 07-24-2014, 11:01 PM
1fastTransAm's Avatar
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Nice ride man.. Wish there was E-85 pumps near me to make this an easier choice. We have 93.
Old 07-25-2014, 08:18 PM
TexasTTWS6's Avatar
You can always switch it to 93 and run meth.
Old 07-31-2014, 04:53 PM
AW794's Avatar
Awesome car. Looks like its struggling for traction. How old are the MT's?
Old 07-31-2014, 11:35 PM
TexasTTWS6's Avatar
Bump!
Old 08-01-2014, 10:27 PM
TexasTTWS6's Avatar
bump for the friday night crew.
Quick Reply: 01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Built T56 | E85
