2002 Camaro Z28 LQ9 6.0liter Like New
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $11000
Mileage: 130000
Location (State): CA
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Black Exterior with Black Leather Interior
New Professionally built 6.0 Liter Engine [built from new GM block] with Edelbrock 61969 Heads (CA Smog Legal)
Heads are CNC Ported and have 2.02 Intake and 1.57 exhaust Valves with 65cc combustion chambers
Compression Ratio is approximately 11:1
Comp Cam 1-54-424-11/ Keith Black 3517HL Pistons / Crankshaft Polished
Stage 3 Transmission O/H 4L60E Complete Beast Sun Shell & / Shift kit / Transmission Mount /
Dynotuned Engine from Cunningham Motorsports
SLP Cold Air Induction Intake
New Pacesetter Headers along with New Pacesetter Y-Pipe 3inch Into / Catback / Pypes M-80 Muffler /
Converter 4L60 LS HP Series Stage II 278mm 1A s/n: 072762
GM Original Balancer 12553118 New Accessory Pulleys and Belts
New Side and Rear Emblems
New AC Delco 1520730 A/C Compressor / A/C Receiver Drier / New Steering Rack / New Alternator /
/ Rebuilt and Ratio Changed GM 7.625 Rear Differential Ratio 3.73 / Shim Kit and Lubrication
New Rear Axles, Bearings, and Eaton TrueTrack Positraction
/ New Steering Rack / New Alternator / New Transmission Cooler /
Wheels and Tires: Weld Prostars 15x8.5 BS 275/60/15R Mickey Thompsons Radials and 165/80/15R Gremax Capturar CF2
12 X 1.5 1.310 Open Chrome style Lug Nut along with New Center Weld Racing Caps
2dr RKS Carbon Fiber Front Upper Grill
Touch screen Kenwood DDX 470 Ebony double din radio bezel GM Harness GM Antenna adapter
Installation brackets with IPod Connecter Hybrid Audio Mirus 6.5'' Coax Speakers Bluetooth Setup
T-Tops with Factory Sunshades
Everything is literally under 5,000 miles and is new from front to rear underneath this car, it has been religiously taken care of since day one from the original owner and was garaged it's whole life, always maintained and waxed polished original paint, nothing has been repainted or damaged all original, interior is perfect no rips or tears anywhere in vehicle. This is a turn key vehicle and everything works heater/ice cold ac. I have almost all receipts from engine assembly, installation, rear end, axles, transmission, gears, ac components, oil changes, stereo, etc.
Vehicle is roughly making 440-460 hp at the wheels currently on a conservative tune from Cunningham Motorsports. Vehicle is listed local, and is subject to prior sale.
