2004 SY Mach 1, Built Motor & D1SC, CCW's
Year: 2004
Make: Ford
Model: Mustang
Price: $20000
Mileage: 43900
Location (State): FL
Color: Yellow
2004 Screaming Yellow Mach 1
-43,900 miles
-Clean Title
-Garage Kept
Interior
-IUP Package
-MGW ***** on heat/AC *****, headlight, and "Eject" **** for cig. lighter
-SOS gauge pod with Cobalt C2 gauges (Boost & fuel pressure)
-Raptor shift light inside A/C vent
-FRPP 5 speed leather shift ****
-Interior is mint with stock seats front & rear.
Exterior
-Paint is in great condition, detailed professionally about 2 months ago.
-6000k HID headlights and fogs
-20% window tint, rear window also has vinyl strip so no dot matrix present
-03/04 Cobra side skirts (side stripe delete)
-03/04 Cobra mirrors
-Polished CCW Classics (engraved center caps)- 18x9.5 fronts 18x11 rears with BFG's all around, rear BFG's replaced 3750 miles ago and fronts have roughly 10k miles. 275 fronts/295 rears.
Suspension/Brakes
-Steeda Sport springs (no iso's)
-Stock shocks/struts
-Eibach front & rear swaybars
-Steeda rear strut tower brace
-Steeda Upper & Lower control arms
-Steeda Full length subframe connectors
-MM caster camber plates
-Welded torque boxes
-FRPP driveshaft loop
-RotorPro's Slotted/Crossdrill Rotors with black centers & Hawk HPS pads
-SLP Line Lock
Exhaust
-Mac Longtubes
-Mac offroad prochamber
-Magnaflow catback
Engine
-Cobra iron block stroker with manley rods and notched pistons. Pistons are coated. Arp mainstuds. 5.0 displacement
-ARP hardware throughout including arp2000 rod bolts, head studs, mainstuds and sidebolts.
-Stainless valves, bronze valve guides, new tensioners, heads are fresh with 1k miles on rebuild
-Stock cams & heads
-Ported lower intake by "Roy" well known on mach1registry.com forums
-Procharger D1SC (head unit was sent to Procharger and rebuilt 4k miles ago), 3.85" pulley on blower, upgraded Procharger intercooler, closed big red race valve
-Converted to 8 rib with all Ford pulleys (laser aligned, all the headache of 8 rib seems to be fully remedied)
-Innovators West 10% overdrive harmonic damper fully rebuilt by IW when new shortblock was put in.
-ThumpRRR single bolt tensioner
-Valve covers and timing cover powdercoated "wrinke" black
-"Powered by Ford" coil covers
-Custom catch can
-Tuned by Tuners Inc with a SCT X-Cal 2 and made 567 rwhp & 486 rwtq @ 18 psi on 14 degrees timing
Transmission
-Liberty 26 spline input shaft
-Centerforce DF Clutch
-Ford Steel Flywheel
-FRPP Aluminum Driveshaft
-Steeda Tri-Ax Shifter
-Steeda Firewall adjuster & clutch quadrant
Rear
-FRPP 4.10 gears
-FRPP 31 Spline Cobra Diff
-FRPP Diff Cover
-Strange 31 Spline Axles
-3" studs (also on front)
-Welded Axle Tubes
Fuel/Air Delivery
-60 lb injectors
-Cobra tank with twin Ford GT pumps
-Dual FPDM
-Fiore hat
-SCT 2600 Maf with maf.ia
I love this car. I am in no rush to sell the car or in any position where I need to get rid of it quickly. Do not waste your or my time by lowballing. I am asking 19.5k . If you have any questions, feel I missed something or would like more specific pictures please feel free to call or text me at 904-477-5169. Located in Jacksonville Florida. Thanks for looking!!!
I get that fairly often with this car, seems to be the rule breaker yellow car for a lot of people.
