89 Formula 350
89 Formula 350
Year: 1989
Make: Pontiac
Model: Firebird
Price: $4500
Mileage: 44500
Location (State): WI
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS1Tech Administrator
Received 1,468 Likes
Couple questions...
Where in WI is the car located?
Do you still have the stock wheels or is it currently on the aftermarket ones seen in the garage picture?
I seem to remember that '89 should have come with a 3.27 9-bolt....so I guess the entire rear has been swapped from an older or newer model?
Thanks.
Thanks.
There is a little surface rust on the body line from rock chips and sitting with exposed metal on the ridge. I've seen it before on a third gen with no ground effects, other wise she is clean
Looks like the rust extends into the lower areas of the front right fender near where it meets the wheel well, and also into the upper corner of the rocker panel near the bottom rear of the door.
It seems to be a nice car other than this surface rust, which would need to be inspected in person and there is no time in the foreseeable future than I can make a trip that far northwest. Otherwise, I would be interested.
The ad also mentions "Comp 256 roller cam" but the only Comp 256 cam I can find is a flat tappet version. Perhaps it has since been discontinued.
