WTT/WTS 35th Anniv. Camaro SS
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $11000
Mileage: 90000
Location (State): GA
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Here are the details...
Car:
Slp # 0717
Upgraded speakers to replace factory (mostly kickers)
New belts and katech solid tensioner
Fully tuned for all work completed
Heat and AC work but I took the AC belt off
Engine;
6.0 lq9 completely rebuilt
Ls3 heads rebuilt with psi springs
Ls3 intake / 90mm tb / corvette 85mm maf
Comp cam (specs?)
Trick Flow pushrods Arp head bolts
LS7 lifters
LS2 lifter tray
LS2 timing chain
LS2 Melling high volume oil pump
Slp air lid / k&n filter
Asp crank pulley
Msd wires
Ls6 vally cover
Sfi approved flexplate
Exhaust;
1 3/4 primary's to 3in collector ceramic coated long tube headers
TSP 3" X pipe
Trans;
Fully rebuilt and upgraded 4l60E
Amsoil synthetic fluid
3200 circle d stall converter
B&m cooler
Deep pan with 2qt added capacity, with cooling fins
Aluminum driveshaft
Suspension;
Bolt in SFC's
UMI adjustable torque arm
Rear axle;
Rebuilt with 3:73 gears
New axles
Recently did the berger panel mod with stainless inserts, fresh tint, DD ZR1's with Nitto's up front and 315 MT ET's out back, brand new SLP 35th anniversary floor mats and trophy mat, and a brand new dash pad from 6LE, fresh drilled and slotted rotors and brake pads. I removed the front impact foam and support along with the windshield washer fluid reservoir (I still have everything except the foam). New DEPO "whister" front blinkers and rear side markers. I also have a brand new Turn One PS pulley because the current one squeaks until the car is completely warmed up. EDIT: Rear seats and seat belts have been removed and will be sold.
The only cons are the front bumper paint is a little faded, torn drivers seat and the passenger side rocker has a small dent towards the rear of the passenger door. Car looks great and cleans up nicely.
I can't get picture post so please text me at 262-370-4740 for pictures and further questions.
