415ci LS3, all new componets
Price: $5500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NC
Item Condition: Used
LS Engine?: Fits LS Engine
I would be interested if it wasn't from 2011, and if you consider selling the short block by itself. also what chamber size do those heads have to make that compression? pics of actual motor? Thanks
That's actually a good question on the compression, these aren't the same heads that were used for those numbers, I need to do some digging. It hasn't been sitting since 2011, sat from then till early 2013, driven occasionally at best until about 6 months ago. I'll see if I cab dig up the original head info.
Looks like you'll have to do your own research, looks like this compression is pretty common on the stroked ls3 builds, quick search I found them with 11.7 to 1 on pump gas, none yet under 11to1.
Price drop. 5.5K. It will be a long block plus the cam, rear cover, intake, fuel rail and LS9 injectors. Oil pan, windage tray, pickup tube, front cover, oil pump, chain and gear are moving to new motor.
