Fully forged 370
Fully forged 370
Category: Engine - Complete Motors
Price: $4500
Location (State): NM
Item Condition: Brand New
LS Engine?: Fits LS Engine
New zero miles ls
LQ4 370CI
long snout crank
rotating assembly fully balanced from balancer to flex plate
forged Eagle H-beam rods
Mahle forged flat top pistons bored 30 over
ring gap for boost 24 thousands
special grind cam from isky racing cams through "stock48"
ls9 7 layer head gaskets
head studs
new rod and main bearings
new durabond cam bearings
317 gm heads
Brian Tooley dual valve springs titanium keepers
New ls7 lifters
New ls7 lifter trays
New front timing cover gasket seal
New rear seal and gasket
Complete long block minus brackets etc.. block has been inspected hot tanked everything professionally done. This set up was built to handle 1000+ to the wheels.
Ready with drain plug and supply plug for a turbo set up.
Compression is at 9.3-9.5:1
I want $4400
Located near albuquerque, nm
Prefer Text 505-three28-1534
Pick up preferred will have to see about shipping.
There is literally over 3k in parts!
Well over 6k after machining, build and parts. It's ready to be bolted in and ran!
Refer to link for pics.
http://http://www.performancetrucks....-370-a-528249/
Does it have arp bolts for the main, rods, & heads if so which ones.
Any work done to the heads?
What are the cam specs?
What reluctor wheel does it have?
What crank does it have?
