Meth lines/nozzles, Procharger Pulleys, Fuel Log, Misc Stuff
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): TX
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
-Alky control stainless meth lines... ends of some lines/nozzle holders/tee fitting were painted black but it is chipping off so they will need to be repainted or stripped bare if you prefer the brass look... includes m5 and m10 nozzles... if you get an inline filter this should be enough line to run from the meth pump to the charge pipe... $75... lines/fittings are -4an and here are approximate lengths of each hose from top to bottom in the following picture:
-33 1/2" from end to end
-23 1/2" from end to end
-7 3/4" from end to end
-5 3/8" from end to end
-Tee fitting- 1 3/4" from end to end, 1" tall from the flat part of the bottom to the tip
-Jegs 90° -10an push-loc fittings... used, some small scratches here and there but nothing major... $30 for all 4
-4.38 procharger pulley, includes bolt/washer/key... this was used on an ecs kit and they machine the shoulders off so the manual tensioner wraps the belt as much as possible... $35
-3.8 procharger pulley... I never used this and believe it is for a mustang due to having only one shoulder and an offset hub... $30
*BOTH PULLEYS FOR $50*
-brand new magnafuel fuel log... -10an orb ports, 6 total (4 on top and 1 on each end)... $45
-d585 truck coil brackets/bolts... $25
-12mm torque tube bushings/guibos, 40k on them... $30
-02 c5z shocks, 40k miles on them... **SOLD**
-02 c5z front and rear springs, 40k miles on them... **SOLD**
-set of intake and waterpump bolts... **SOLD**
