2000 Camaro street/strip legal
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $19500
Mileage: 50400
Location (State): TN
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
-Iron 6.0L block
-ARP main studs
-Eagle H beam rods
-Mahle 4.005 Flat top pistons
-Ported Dart Pro 1 225s 58cc / 12.1 Compression
-BTR .660 springs w/tit retainers
-Manton 11/32 Pushrods
-Morel Roller lifters
-Tick ported oil pump
-JP billet timing set
-ARP head studs
-Custom grind cam by Martin Smallwood
-Super Vic intake
-Holley 4150 TB
-racetronix 42lb injectors
-Zex perimeter plate kit…75-300 hp
-Nitrous Outlet dedicated fuel system for F-body
-Kooks 1 7/8 Headers
-3in Y pipe to 3 1/2in race bullet and dump
-MWC solid mounts
-Tuned by Ed Hutchins
DRIVETRAIN:
-TH400
-Trans brake and RMVB
-Ultra bell
-Alum deep pan
-Yank, 3600 eliminator Converter (for nitrous)
-B&M Stealth shifter
-3.5 steel driveshaft
-Moser 12 bolt rear… 33 spline axles…5/8 studs
-4.11s Detroit locker
- Moser alum rear cover
-BMR tubular suspension
-xtreme spohn anti-roll kit
-K member
-control arms (upper lower fronts and rears.
-torque arm (xtreme)
-SFC
-Panhard
-Weld pro stars 15x3.5 and 15x10s Rear
- 28x11.5 Hoosier QTPs
-manual brakes…4 wheel disc with all new Calipers.
-line lock
BODY:
-50,400 miles
-VFN Sunoco extended hood
-Racecraft rails
-Power windows, Locks, Radio all work.
-No wipers or AC
-Wolfe 6 point bolt in roll bar
-Firebird manual seats
-New carpet for console delete
-Aem 320lph e85 Fuel pump
-Racetronix Fuel Pump hot wire kit
-battery relocation kit w/push off switch
-Innovate Power Safe nitrous wide band
-Lingenfelter 2-step and timing retard
-Raptor shift light
-hood was recently painted to match car perfect.
-New Headlights
Probably forgetting a lot of other things. Car runs 10.70s NA with tight nitrous converter and been best of 9.76 at 140mph on 150 hit. Only been to track few times at end of the 2015 season. 8 runs total on this new motor.
Can run on super unleaded 93 pump gas if not spraying N20. Fun car and very street able. Can be driven anywhere within reason.
Clean and clear title for car. 615/476-3750
You tube Videos..
Thank you for the compliment. this spring we've added Nitrous Outlet F-body dedicated fuel system...Moser 5/8th studs...2 new Cam lock seat belt harness...also 2 new drive-shaft loops and several other detail things...
The car has not had anymore runs put on it since one outing this spring.
everything is fresh...and yes, it is a beautiful 50K mile car...clean title and a true SS car with all the documentation. It has a strong well built engine with all good internal rotating assembly parts.
thx for the compliment...send me a buyer!
