Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Large shop clean up tons of ls parts up for sale
Old 04-23-2015, 10:58 PM
Closed ex-Sponsor Account
matt510's Avatar
Default Large shop clean up tons of ls parts up for sale updated 5-22
Category: Engine - Intake/Fuel
Price: $5
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): TX
Item Condition: Used
LS Engine?: Fits LS Engine
Large shop clean up and have a huge quantity of new and used parts for all LS based vehicles. This includes C5, C6 Corvettes, F-Bodys, 5th Gen Camaros, CTSVs, GM Trucks. Here's a list of a few items up for grabs.
UPDATED 5-22-16
-FABRICATED ALUMINUM TALL LS VALVE COVERS Pictured above----- $80 SO **SOLD**[/B]
-LS7 CORVETTE 7.0 RED ENGINE COVERS ---------------$100.00 **SOLD**
-GT-45 TURBO 750HP ***NEW***------------------$475.00 **SOLD**
-GEN III 4.8/5.3 LS ENGINE BLOCK-----------$100.00 **SOLD**
-DOUBLE ROLLER TIMING SET FOR LS2 Motor (Half moon) MOTOR **NEW**----------$125.00 **SOLD**
-CTSV BOSCH INTERCOOLER PUMP-----------$65.00
-GEN III AND GEN IV LS CAM GEARS---------$15.00
-NEW LS3 TIMING COVER----------$60.00 **SOLD**
-2010+ SS CAMARO BALANCER----------$95.00 **SOLD**
-LS3 LS2 4.8 AND 5.3 MISC RODS AND PISTONS------LET ME KNOW WHAT YOU NEED The 5.3 and 4.8s I have are all Gen IIIs no Gen IVs
-2012 C6 CORVETTE LS3 EXHAUST MANIFOLDS **SOLD**
-TSP LS7 7.750 3/8s CHROMOLY PUSHRODS--------------$50.00
MISC BLOWER PULLEYS (6-RIB) FOR VORTECH PROCHARGER WHIPPLE $45.00 **SOLD**
-Magnacharger 6 rib supercharger pulleys in misc sizes let me know what you are looking for.
-F-BODY BRAKE BOOSTERS------------$40.00
-STOCK LOW MILE PLUG WIRES C6 CORVETTES 5TH GEN CAMAROS---------$45.00 A SET
-C5 FRONT A-ARMS AND SPINDLES------------$375.00 **SOLD**
-**NEW**TSP 7.350 PUSHRODS----------$70.00
--1/2 OF A SET OF COMP CAMS 7.425 5/16s PUSHRODS--------$25.00
-BTR DUAL .650LIFT SPRINGS (SPRINGS ONLY)$40.00 **SOLD**
-C6 Z06 BI MODE CAT BACK 20K MILES ------------------$450.00 **SOLD**
-STOCK C6 BASE MODEL AND C6Z06 FACTORY H-PIPES-------------$100.00
-STOCK ZR1 X PIPE 3 INCH------------------$100.00
-STOCK LOW MILE LSA FACTORY CAMSHAFTS, VALVESPRINGS, PUSHRODS----$160 **SOLD*
-STOCK LS3 CAMARO CAMSHAFTS, VALVESPRINGS, PUSHRODS-----$160 **SOLD**
-LS1 24X CRANKSHAFT HAS SURFACE RUST BUT NO SCARING ON THE JOURNALS -----------$100.00
[B]-2006-2008 C6 CORVETTE WATER PUMP ---------------$65.00 **SOLD**
-2010+CAMARO EXHAUST MANIFOLDS -----------$125.00 **SOLD**
-2010+CAMARO AC CONDENSER AND LINES------------------$200.00
-STOCK LS7 VALVE SPRINGS------------------$40.00
-LS2 MAFs--------------------$50.00
-F-BODY BLACK BMR ADJUSTABLE TORQUE ARM *NEW----*---Pictured above $175.00 **SOLD**
-F-BODY MISC EBONY INTERIOR PANELS AND PLASTICS--Txt me what you need
-LS1 VALLEY COVERS-----$20.00
-LS1 TIMING COVERS--------- $30.00
-ROCKER ARM STANDS FOR ALL LS ENGINES ------------ $20.00/Set
-STOCK BALANCERS FOR C6Z06------------------$75.00
-STOCK VALVE COVERS FOR LS ENGINES-------------------$65.00
-BOSCH 44.4LB INJECTORS PART#0280156030 PINKISH PURPLE COLOR---$125.00
C7 Z51 EXHAUST MANIFOLDS, CAT PIPES AND X PIPE---------$450.00
-C6 CORVETTE AUTOMATIC A6 BELL HOUSING AND FLEX PLATE -----------$200.00 **SOLD**
-CTSV/ ZL1 OEM LSA BALANCER PULLEY-------150.00 **SOLD**
-LS3 Valley Cover with PCV Port (Black) ----$95 *SOLD*
-Circle D Triple Disc Pro Series Billet Torque Converter for a 6L80E 3200-3400rpm stall speed. ($1200 new) Only 2k miles Doing a powerglide conversion so this converter will no longer be needed---- $800 **SOLD**
-GM OEM C6 Z06 RED REAR BRAKE CALIPERS ROTORS PADS AND STEEL BRAIDED LINES ------$550.00
-GM OEM FOG LIGHT COMPLETE ASSEMBLIES FOR C6 GRANDSPORTS, Z06s, ZR1s WITH HID BULBS - REMOVED THEM FROM MY GRANDSPORT (HAVE TO REMOVE DUE TO INTER COOLERS GOING IN THE FRONT BUMPER AREA) $100 FOR BOTH SIDES
-C6 CORVETTE AC COMPRESSOR 20K MILES --------$125.00
-C6 CORVETTE AC CONDENSOR AND AC LINES 20K MILES -------$140.00
-QTY 7 REV 2.200" STAINLESS LS7 INTAKE VALVES AND 7 REV 1.610" -STAINLESS EXHAUST VALVES--------$80.00
-GEN III 4.8 CRANKSHAFT (SHORTER STROKE) - WILL NEED TO BE POLISHED JOURNALS HAVE SURFACE RUST BUT NO SPUN BEARINGS-- $80
-SET OF GM YELLOW BEEHIVE VALVE SPRINGS AND RETAINERS -$40
-SET OF LS7 CYLINDER HEADS WITH THE FACTORY TITANIUM INTAKE VALVES AND SODIUM FILLED EXHAUST VALVES ------$1100.00
-C6 CORVETTE ABS MODULE (EBCM) 20K MILES -----$350.00
-C6 FACTORY HARMONIC BALANCER PULLEY-$100.00
-C6 Z06 DRY SUMP FACTORY HARMONIC BALANCER PULLEY--$100.00
-BRAND NEW UN OPENED FIC FLOW MATCHED 850CC AT 43.5PSI FUEL INJECTORS SHORT STYLE FOR LS3 LS7 LSA LS9 -----$550.00
-MOTION RACEWORKS Gen 4 Turbo -10 Drain Timing Cover Gloss Black Powdercoat BRAND NEW -GOT IT FOR MY CAR BUT IT WILL NOT WORK WITH THE VETTE BALANCER BEING SO CLOSE TO THE COVER COMES WITH STAINLESS BOLTS AND NEW CRANK SEAL ALREADY INSTALLED $120.00
-----SHIPPING AT BUYERS EXPENSE------------
Shoot me a txt to 713-503-4208 or a PM with any questions or pictures. Please be specific about what items you are interested in. Thanks!
-Matt-
Attached Thumbnails Large shop clean up tons of ls parts up for sale-img_1055.jpg   Large shop clean up tons of ls parts up for sale-img_1054.jpg   Large shop clean up tons of ls parts up for sale-img_1053.jpg   Large shop clean up tons of ls parts up for sale-img_1052.jpg
Old 04-24-2015, 06:30 AM
Mike Cordero's Avatar
Default Need one LS2 piston
Sorry but I would need only one LS2 piston (1.2 mm top ring, not 1.5 like the LQ9); the rods is not a must. Do you have two LY6 (6.0L) pistons with rods around (4.0 bore with valve relieves)? How much for each item? Can you send me a pictures of the damaged part of the F body oil pan? My email is mikezcars@yahoo.com. Do you that the repair needed is an easy one or wll need some extra time to fix it?
Old 04-24-2015, 06:57 AM
5FOX3's Avatar
Got any after market 3.78 bore 5.3 pistons?
Old 04-24-2015, 08:22 AM
kainedogg's Avatar
This is a Garrett GT45 right?
Old 04-24-2015, 08:25 AM
RollingDumpster's Avatar
How much for 8 floating LS2/LS3 rods? Any 24X cranks laying around?
Old 04-24-2015, 09:02 AM
spent21's Avatar
Interested in a full set of Gen III 4.8 flat top pistons w/o rods. Building a high comp. 5.3.
Old 04-24-2015, 10:33 AM
laurentj23's Avatar
Ls1 crank shipped to 30121
Old 04-24-2015, 12:59 PM
matt510's Avatar
I do have one LS2 piston and rod for $30.00 but no LY6 pistons and rods. Here is a picture of the crack on the oil pan
Old 04-24-2015, 01:00 PM
matt510's Avatar
No I only have a stock set at the moment
Old 04-24-2015, 01:04 PM
matt510's Avatar
I don't have a complete set of 8 rods at the moment but I do have a couple of 24x ls1 cranks for $130 shipped
I have a complete set of rods and pistons from a 4.8 for $75.00 shipped
$130 Shipped
Old 04-24-2015, 01:05 PM
It's the one that uses the 1.2mm top ring? #0.00 shipped or plus shipping?
Old 04-24-2015, 01:25 PM
matt510's Avatar
Yes it uses the 1.2mm top ring. it would be $35.00 shipped to you.
-Matt-
Old 04-24-2015, 01:29 PM
-Matt-
PM me your PP address for the payment; I'll take it. Thanks.
Old 04-24-2015, 08:57 PM
matt510's Avatar
All PMs replied and list updated
-Matt-
Old 04-25-2015, 01:39 AM
liketowork's Avatar
Do you have a set of LS2 or LQ9 pistons an 6.098/.927 rods? Thanks!
Old 04-26-2015, 01:03 AM
chrisp250r's Avatar
What sizes do you have in the 6 rib pullies?
Old 04-27-2015, 12:37 PM
matt510's Avatar
I don't have a complete set of LS2/Lq9 Pistons or 6.098/.927 rods at the moment sorry
What blower do you have?
Old 04-30-2015, 02:49 PM
ss84carlo's Avatar
I sent pm few days ago? Lsa injectors?
Old 04-30-2015, 08:00 PM
Ratical's Avatar
Interested in a set of the fabricated valve covers. Do you have the mounting hardware? Could I get some pictures of the mounting rail area and do they take the factory gaskets?
Thank you.
Old 04-30-2015, 08:12 PM
matt510's Avatar
PM has been responded to. It's been a little busy here around the shop lately
Originally Posted by LXinMS
Sent text from 228 area code regarding timing cover
Txt was responded too.
Thank you.
These valve covers do not have the provisions for the coils to be bolted directly onto them if that is what you are referring too. I do have the bolts and grommets for them though and they take factory gaskets.
-Matt-
Quick Reply: Large shop clean up tons of ls parts up for sale
