2000 Pontiac Trans Am 6spd 47k Miles
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $7300
Mileage: 47800
Location (State): NC
Color: Purple
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
The car is located in Reidsville, NC, about 20 minutes north of Greensboro.
This car has a clean NC title, however the carfax shows the car had a salvaged title in Virginia. The previous owner told me the car had been rear ended, and he replaced the rear clip and repainted the entire car. It then sat for 7 years until I bought it. This car has been aligned and tracks straight, there are no issues what so ever regarding the rear clip being replaced. It was done right and professionally, and you can not tell unless you look under the car, which I will gladly show you.
Here is what has been done to the car and some other info:
-C6 Corvette wheels with good tires, 1.25" spacers
- Lowered (1.5 coil cut from springs, still rides great)
-Magnaflow muffler
-Windows Professionally tinted legal 35% all the way around
-All Relays replaced
-Oil Changed at 40k and 45k miles
-Transmission fluid topped off
-TTops work great, only leak under high pressure like a pressure washer or auto car wash
-Sometimes reverse will grind, but if you shift to 1st gear before reverse, it will shift to reverse smoothly every time (I got in the habit of going 1st then reverse and it never grinded)
-One of the reverse lights doesn't work, it needs a new socket
-Check engine light is on for the air system emissions check valve (either replace or get the computer tuned to tune it out) I have the replacement check valve
-The sound system sucks, one of the speakers is blown
-The is a large scratch on the rear bumper
I have the title in hand.
This is your chance to own a beautiful low mileage Fbody. While it is not perfect and does need a little work, it is a one of a kind. This car has been great but I have moved on to a Corvette, so this needs to go. Please feel free to contact me with questions or offers.
