Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump
Old 11-23-2016, 07:02 AM
  #41
JRMClassics's Avatar
Price: $1
Location (State): NC
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
^ Sorry, forgot to send you those pics. I'll text them to you now. And this is the Katech link to the pump.
http://store.katechengines.com/high-...pump-p261.aspx
Old 11-23-2016, 07:09 AM
  #42
Here are some more pics of the dry sump setup.
Attached Thumbnails LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161105_155147.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161123_064205.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161123_064253.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161123_064359.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20160804_194818.jpg
Old 11-23-2016, 12:22 PM
  #43
02_ramair_ta's Avatar
msg sent
Old 11-24-2016, 11:23 AM
  #44
Happy Turkey Day!!!
Heads are SOLD. Still have complete shortblock and intake setup.
Old 11-26-2016, 06:39 PM
  #45
Buyer backed out on the heads....
These heads have been milled by WCCH and are their E85 head. On the 440 longblock that I had them on they work fine with pump gas due to the dished pistons. However, they are 51cc and designed to be a bolt on for someone wanting to runs E85. On a stock LS7 rotating assembly they will put you at 13.9:1. So if anyone out there is looking to run E85 these are perfect.
Old 11-28-2016, 07:23 AM
  #46
StoneColdLT1's Avatar
Still have the LS7 shortblock for sale?
Old 11-28-2016, 07:00 PM
  #47
Yes I do....been communicating back in forth with a potential buyer for everything but no payment yet.
Old 11-29-2016, 07:36 AM
  #48
I have to do some research to see what the cost would be to fix those sleeves to see what the end cost would be. I have basically an entire LS7, minus the block. Your crank and pistons are nice but would you consider selling just the block if your seller falls through? I'm in jersey but I have a couple friends in NC as well as up and down the east coast that'll be coming home for the holidays so I could probably save you shipping.
Old 12-02-2016, 06:54 AM
  #49
Would like to just sell everything together but open to offers for just the block.
Old 12-08-2016, 07:19 PM
  #50
Katech oil pump sold. Still have the rest.
Old 12-13-2016, 07:03 AM
  #51
Bump. I'll take $2,500 cash for everything that is left.
Old 12-13-2016, 08:46 AM
  #52
bottledgto's Avatar
What's left ?
Old 12-14-2016, 11:51 AM
  #53
WCCH CNC Stage II LS7 heads
LS7 440 shortblock has Eagle stroker crank and rods, Wiseco pistons and ARP main studs. Motor will need some repairs as it has hairline cracks in the tops of sleeves 3 / 5 & 6. Also spun #6 rod bearing so crank will need cleaned up. Would recommend just buying a new set of rods vs. reusing.
C6 dry sump oil pan with pickup tube
Trickflow 7.75 .080 hardened pushrods
Factory water pump, front cover, rear cover, valley cover, valve covers and rockers.
Old 12-19-2016, 08:37 PM
  #54
Bump.
Old 12-19-2016, 09:29 PM
  #55
Received 3,360 Likes on 2,078 Posts
Interested...what stroke is the crank, and how bad is it? Will it have to be simply turned, or will it have to be repaired/reground? Are the pistons ok?
As for the cracks in the sleeves, do they terminate in the sleeve? Did you see coolant in the cylinders?
Old 12-20-2016, 06:53 AM
  #56
4.100 crank, pretty galled up on #6 but I haven't mic'd it. Pistons all look fine...have some marring on the skirts but nothing more than what I would consider cosmetic. Cracks in the sleeves are all on sleeve to sleeve contact points at 3 and 9 o'clock positions. I'll post up some pics in a bit.
Old 12-20-2016, 03:36 PM
  #57
Pics of cracks
Attached Thumbnails LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20160508_212232.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20160508_212115.jpg
Old 12-20-2016, 03:40 PM
  #58
Pistons and crank pics
Attached Thumbnails LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161112_190359.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161112_190338.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161112_190348.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161112_190252.jpg   LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump-20161105_160406.jpg
Old 12-22-2016, 05:10 PM
  #59
Bump.
Old 12-27-2016, 02:31 PM
  #60
Shortblock sold.
Quick Reply: LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump
