Complete engine - 402 ci LQ4 LQ9 Iron Block stroker w/ AFR 225 heads, boost setup
Price: $6500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
AFR 225 heads w/ 72cc chambers
Thunder Racing blower cam (225/233 .642/.595 115LSA)
Comp 7.375" pushrods
Callies Dragonslayer crank shaft
Callies Compstar rods w ARP 2000 rod bolts
Diamond pistons w/ -22cc reliefs
Melling high-flow oil pump
Comp adjustable timing set
ATI Super Damper harmonic balancer
FAST 90mm intake manifold (painted black) w/ FAST 90mm TB (anodized black)
FAST fuel rails w Motron 60lb injectors
ALL engine covers and F-body accessories included (160* t-stat in stock water pump)
F-body oil pan
Driver's side valvecover has AN fitting welded on and connects to a braided stainless line feeding a Moroso catchcan
Stock coilpacks w brackets.
**********SOLD**********
any interest in a trade for a fully forged iron 402 shortblock with a very healthy cam for your shortblock minus cam? also right at 10k miles and built by Texas Speed and about 2 hrs south of you. can make it a long block plus cash on your end and we can trade pcm's and it's already tuned. ran the numbers in my sig and has 9 sec capability on motor with a lighter chassis, more gear and a trans brake. rev limiter set at 6800 so it's never been pushed and runs on 91 oct all day long! just throwing it out there. i'd just like a little less comp for my turbo setup if possible and if not, i'm perfectly happy keeping it.
