WTB: 4 channel axle shaft
Old Jul 15, 2012 | 12:39 PM
giiventofly's Avatar
Default WTB: 4 channel axle shaft
I'm replacing a wheel bearing in a 99 z28. The bearing surface on the axle is damaged and I have read a lot of bad things about the use of repair bearings on tcs axles.
So I am looking for a 4 channel axle shaft (one with the reluctor ring)
Thanks!
Old Jul 15, 2012 | 09:55 PM
JasonShort's Avatar
I have a coupe in great shape. Drop me a PM if you are still looking for one.
Old Jul 16, 2012 | 11:35 AM
Thanks. I may end up doing that but I was hoping for something a little closer.
I live in Carlisle on weekends and Williamsport during the week.
Old Jul 18, 2012 | 08:49 PM
2kblackgtp's Avatar
Can't the reluctor wheel be pressed off the old axle and pressed onto a 3 channel? If so, Ive got a 3 channel axle
Old Jul 20, 2012 | 07:55 PM
I thought so, but it sure doesn't look like it? I have four 3 channels and no use for them.
Old Jul 23, 2012 | 11:43 AM
stillllll looking
Old Jul 28, 2012 | 01:24 PM
bump this one more time before I go a different route
thanksssss.
Old Jul 29, 2012 | 05:28 AM
nerisls1z's Avatar
I have a set of 4 channel axles from my 9 inch build but the no longer have rings on them took off to put on 9 in philly though
Old Aug 11, 2012 | 01:11 PM
unfortunately I'll be needing the rings as well.
Old Aug 11, 2012 | 09:22 PM
JasonShort's Avatar
Still have mine. It's easy to put it in a box and ship it It still has the ring on it as well.
