01 TWIN TURBO T/A in NJ w/videos/pic PAGE 2
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $15800
Mileage: 83000
Location (State): NJ
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
The car has 83K miles on it - the turbo kit, built motor, etc. all have 9K miles...
Car was just retuned - made 615/607 on a Mustang dyno that is known to read 22% low ... so that's 788/778 on a dynojet... this is on 13.5psi, 15* of timing and 11.2 A/F ratio
The black exterior is damn near flawless - seriously looks like a car with 20K miles...
Interior is perfect as well.. Car still has full heat and A/C...
• Modifications
Engine:
• Stock aluminum block LS1 (5.7L), bored .010 over (348 ci)
• Polished crank and fully balanced rotating assembly
• -16cc Mahle forged pistons w/ file-to-fit rings (filed for blown/turbo application) 9.0:1 compression ratio
• Eagle 4340 forged H-beam connecting rods w/ ARP L19 bolts
• Clevite bearings throughout
• Ported and polished 5.3 heads (heads/valves have 3000 miles)
• ARP head studs
• GM MLS head gaskets
• Comp Cams 220/224 .564/.568 115 lsa, custom turbo grind cam – custom grind for mid-range torque
• LS2 timing chain
• LS6 ported oil pump
• LS6 intake manifold
• Patriot Performance Gold dual springs, with titanium locks and retainers
• LS7 lifters
• NGK BR7EF plugs
• Full A/C, heater, etc.
Turbo Kit:
• 58mm Precision turbos (2) – T4
• Custom built, thick walled stainless steel headers
• 3” Stainless steel downpipes, connecting into 4” stainless exhaust, then dumped before the axle
• Stainless steel charge piping
• Very large 2in – 1out air-to-air intercooler (polished)
• 38mm Tial wastegates (2)
• 50mm Tial Blow-off valve
• eboost2 Electronic boost controller in vent
Fuel System:
• Twin 255lb Walbro fuel pumps (2)
• Custom pressed steel-braided fuel lines
• Aeromotive fuel pressure regulator
• Aeromotive fuel rails
• 83# high-impedance fuel injectors
• Mallory fuel gauge isolator
• Snow Performance Boost Cooler methanol injection kit
Supporting Mods:
• T56 6-speed manual transmission
• Spec Stage 3+ clutch – 1000 ft.lbs tq. capacity (1200 miles)
• Custom aluminum driveshaft
• Moser 12-bolt rear end
• Detroit True-trac differential w/ 3.08 gear ratio
• A-pillar 3 gauge pod – wideband o2 (a/f), fuel (psi), boost/vacuum (psi/hg) and eboost2 in the left vent
• Custom short-throw shifter
• Custom “in-floor” subframe connectors (2”x4”)
• BMR tubular K-member
• Polyurethane motor mounts
• US Exotics Superhawk fiberglass hood (1 of 500 made)
• Custom 3-bar speed density tune
Serious people only please. My email is itlylawboy@hotmail.com. The car is an absolute freak of nature to drive. The turbo sound is awesome and the car pulls like a freight train. Car has never been to the track with this turbo
Why thanks for the kind words. Too busy with work to get updated pics. Hopefully this weekend if crazy weather holds off
