BRAND NEW Fire Storm Digital Dual Stage Nitrous Controller!
Category: Engine - Electrical
Price: $225
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): IL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
I have a brand new Fire Storm digital dual stage nitrous controller (can run a single stage only if you wanted).
This is a brand new never used piece. This is made by the same person who designs and builds all of the Lingenfelter electronics. This was literally handed to me in person by him.
No need for a full throttle switch. Has built in window switches and is activated by throttle position once you arm it.
Here is some technical info:
Progressive Nitrous Controller, 2-Stage, Dual Ramp - Micro Storm
The Micro Storm progressive nitrous controller provides control for 2 stages of nitrous in a extremely small package of just 2 7/8" x 1 3/4" x 3/4".
The billet aluminum encloser is anodized black with a 3 digit display and 3 high quality push buttons for easy programming and navigation through the setup menu. The Micro Storm can handle 40 amps on each stage of nitrous so this tiny controller can be used with any nitrous solenoids on the market including Pulsoids, NX, NOS, Edelbrock, MPS, Dynotune and others. Additionally each stage of nitrous can be programmed from 10-40 hertz and have a dual ramp to give you even more control of power down slippery tracks or to prevent those monster 1/8th mile or 3rd gear wheelies.
This little jewel also has a TPS (throttle position) input and tach input for easy wiring on any vehicle. A shift light output is also provided but can be configured for use as a timer ouput to activate a stage of ignition retard.
One of the best features of the Micro Storm is its ability to store up to 5 different nitrous configurations that you have programmed. This is perfect for those who run in multiple classes that need more or less power to run their number.
Highlights:
Billet aluminum black anodized encloser with high quality push buttons for programming
Easy to read digital display
Controls 2 stages of wet and/or dry nitrous
Each stage can have its own hertz setting of 10-40 (cycles per second)
Dual ramp mode for each stage for more precise control
TPS and tach input for easy wiring and safety
Easy quick setup for TPS input
Shift light or timer output
Compact Size (2 7/8" x 1 3/4" x 3/4")
For those who are looking for a simple to use controller with a bucket load of features your search ends here.
New they $300.
$225 shipped to the lower 48.
First come first serve via PM.
Thanks,
Tim
