Go-fast parts!
Category: Accessories
Price: $1234
Location (State): NC
Item Condition: Brand New
LS Engine?: Fits LS Engine
Nasty nates fuel rails, -8 crossover, -6 an line to tank and all fittings and adaptors to hook to stock fuel system and use the stock feed as a return. $500
Internal walbro 255 in fuel sender unit from '00 transam (regulator removed) $200
Inline walbro 255 (new) $100
T56 transmission comes with bellhousing, shifter $1700
Moser ford 9in with 4 channel ABS. strange center, Daytona pinion support, 4.30 motive gears, nascar Detroit locker, 31 spline moser axles $2500
MTI performance LID $100
Pacesetter long tube ceramic coated headers $300
Ported TB with sensors $150
custom 2.5 bar map plugs up to stock connector has a vacuum line to remote mount and run to intake $75
3" y-pipe with cutout plate $150
3" catback hooker $300
T top (passanger side) $50
engine harness $300
2003 cobra injectors with adaptor harnesses $100
spohn adj torque arm-black with hardware and poly mount $275
umi panhard rod dual heim joint- black $125
umi lca's single heim joint-black $150
ls1 6spd ecu from 2000 trans am $100
ws6 rims $500
stock 4 wheel abs module $150
2000 trans am steering column good condition. (wheel has stereo controls. has airbag. black leather. wheel has some expected wear where you hold it. have keys if needed) $
factory monsoon ampm 6 disc changer and headunit $
Passenger airbag from 2000 trans am. $
spec 3+ clutch and lightweight flywheel (slips) $300
***** Prices do not include shipping or paypal fees.
