They said it couldn't be done....
Old 01-14-2014, 05:36 PM
sschoeffler's Avatar
Thumbs up They said it couldn't be done....
So I've been working on a twin turbo build for approximately 3 years now. I've been needing twin turbo headers but didn't want to fork out $1200 for a pair, disliked the set that stainless works has because they are no where near a match. The passenger side header bends over to the drivers side really hard. I didn't want to take my car to a shop and have an open ended price except time and material and time is $70/hour. So what did I do? I did what they said couldn't be done....I got a set of stainless steel headers off eBay for $280 shipped. Oh and by the way, yes, they are 1 7/8" headers. What had to be done? Simple...cut the header from the flange, take them to a local welder and get them re-welded. Now, granted I have to get the coils relocated but that's really no big deal....you can buy those also for $99 shipped. Here is a picture of the proof.
Old 01-14-2014, 05:59 PM
HexenLord's Avatar
http://www.ebay.com/itm/LS1-LS6-LSX-Up-Forward-Turbo-Headers-Manifolds-Header-Manifold-GM-V8-Chevrolet-/291056345871?pt=Motors_Car_Truck_Parts_Accessories&hash=item43c44f630f&vxp=mtr
Old 01-14-2014, 06:45 PM
Rob Carlson's Avatar
damn... you d realize that 1 7/8 into 3in is grossly over sized for a turbo setup
Old 01-14-2014, 06:58 PM
HexenLord's Avatar
I actually ended up finding the manifolds I linked earlier on ebay for less than $250 shipped.
I'm not sure I understand what you're doing, OP. What did 'they' say couldn't be done? What had to be modified on the manifolds? You just said the flange and re-weld.
Old 01-14-2014, 07:50 PM
slowlsx's Avatar
Yea... im confused
Old 01-14-2014, 11:42 PM
That's it...re-weld the flange...the oil fill tube will have to be re-welded in the center of the valve cover but other than that, they fit. The header had to turned in toward the head about 1/2" at the flange. Also these eBay headers did not factor in port spacing so one of the vbands sticks out a little further than the other one. This will of course be re-done as well. I was wanting a very nice and symmetrical setup.
As far as who said it couldn't be done, that was Josh @KYturbo when he designed the up and forward turbo headers for stainless works.
Old 01-14-2014, 11:47 PM
Those are the headers I purchased also. I spent $30 more but no big deal. They don't fit out of the box fyi. They must be modified.
Old 01-15-2014, 02:46 AM
Mel Carlson's Avatar
LOL and this is why people think they're saving money and they end up spending almost as much as a real set of headers would cost on insufficient garbage
Old 01-15-2014, 03:41 AM
I have $280 in the headers and 120 in welding labor. Show me a set of stainless twin turbo headers for $400
Old 01-15-2014, 05:36 AM
HexenLord's Avatar
The headers I posted from eBay aren't application specific. Just because they don't fit doesn't mean they are useless junk. I'm sure they would fit in almost any older car, F-body figment is tight.
Old 01-15-2014, 05:56 AM
LS1NOVA's Avatar
Nice job. Now dont come back bitchin' when the shitty China tubing cracks.
Old 01-15-2014, 07:31 AM
Cam72aro's Avatar
Exactly!! Turbo headers get extremely hot. That's why everyone uses manifolds including myself. It's stainless that rusts, ie cheap bullshit that will crack when heat cycles a few times.
Old 01-15-2014, 08:03 AM
MUSTANGBRKR02's Avatar
Add in the required coil relocation. And you are at 500
I went with the SW headers and am glad I did.
Old 01-15-2014, 02:01 PM
Twin turbo c5's Avatar
They'll be fine for awhile hopefully. Goodluck with your build should work good once you get everything lined out. It would also help putting some braces off the head to maybe delay any stress cracking.
Old 01-15-2014, 02:10 PM
Blackpanther99's Avatar
I hope those headers work out for you man.
Old 01-16-2014, 08:19 AM
BMF_Racing's Avatar
x2, let us know when its all finished ... pics.
Old 01-17-2014, 10:43 AM
hardbodeez's Avatar
Well if they crack that means the Huron Speed manifolds/headers will crack as well, since they are China metal.
Old 01-17-2014, 11:13 AM
The other one is getting welded up now. Had to remove the power steering pump and put an electronic pump in. No big deal.
Old 01-17-2014, 04:13 PM
Old 01-17-2014, 04:15 PM
Next thing to be welded is o2 sensor bungs and carry the pipes to the turbos
Quick Reply: They said it couldn't be done....
