416 LS3 Build Underway (Pics inside)
Old 08-29-2014, 07:47 PM
BOLO's Avatar
Default 416 LS3 Build Underway (Pics inside)
My 416 LS3 short block is finally done. Thanks to Tony@Speed Inc., as well as Eric who machined and put the short block together, did a fantastic job. The block looks awesome and clean! It took awhile, but it was worth the wait. I will post more pics as the build progresses.
Your thoughts and inputs are greatly appreciated, thank you.
Callies 6.125 Ultra rods
Callies 4.000" forged crankshaft/ARP main studs
New GM Timing cover
Wiseco slugs
GM LS3 aluminum block
Old 08-30-2014, 06:53 AM
conan's Avatar
Very nice, whats the plans / goals for this LS3 ?
Old 08-30-2014, 09:47 PM
conan's Avatar
Sounds like fun, good luck with her.
Old 08-31-2014, 07:03 PM
Kytong's Avatar
Bolo, looks like it's going to be a killer setup!
Old 09-01-2014, 08:09 AM
SmokedOutZ28's Avatar
Finally joining the ls side. Sucks to hear about the LT but you will forget all about it the first cruise in the 416
Old 09-01-2014, 08:38 AM
Rise of the Phoenix's Avatar
Very nice. Should be stout.
Old 09-01-2014, 11:37 AM
Jimbo1367's Avatar
I'm sooooo jealous, you bastard. LOL
Old 09-01-2014, 02:23 PM
BOLO's Avatar
Default More pics
Posting more pics of Go Fast parts. Btw, this will be a 13.0:1 CR n/a ALL MUSCLE!
I went with the Kooks 2"x3.5" headers.."go BIG or go home"LOL
Then theres the Accufab 4500 polished throttle body and Meziere EWP
Sorry, pics are too big.
Old 09-01-2014, 02:30 PM
D9HP's Avatar
Gorgeous headers.
Following along for your ride.
Old 09-01-2014, 02:48 PM
xdanny510x's Avatar
Whats ur rwhp goals and time goals with this set up? Why carb style set up versus elbow/tb set up or fast 102 set up
Old 09-01-2014, 03:14 PM
BOLO's Avatar
Power goals? I never really thought about it. And at 13.0:1 CR, I guess whatever it takes to run in the low 10's n/a as mentioned on post #3.
The single plane efi carb type intake seem to be the ticket for alot of builds, especially since this is not my daily driver anymore. Plus, it's about half the money spent on a Fast 102/102 intake system. I don't think I can go slower or not make any power going this way
Old 09-01-2014, 04:57 PM
LilJayV10's Avatar
Very nice. That thing should fly.
Old 09-02-2014, 07:41 PM
D9HP's Avatar
Originally Posted by BOLO
Power goals? I never really thought about it. I guess whatever it takes to run in the low 10's n/a as mentioned on post #3.
Can you give me some more information on this?
Are you getting more top end out of that setup?
Would love to hear more about this as I am planning to use a Fast 102/102 intake system ($$$$) and have the room under the hood.
Old 09-02-2014, 08:52 PM
BOLO's Avatar
It's all in the heads and air induction system. Don't get me wrong, the Fast 102/102 was initially what I was going to go with, but since it's more of a track car, I went with a race oriented single plane set up, and yes it will make the engine breadth a lot better which will yield to more mid and top end power. You will also need hood clearance for it, so an aftermarket hood is a must. I have a VFN wide Sunuco hood.
Old 09-03-2014, 05:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Sounds like a badass combo.
Let me know if you hit GLD.
Old 09-03-2014, 05:53 PM
Briou's Avatar
Gonna be badass man...can't wait to see it running
Old 09-16-2014, 10:10 PM
kinglt-1's Avatar
Nice setup! Does that intake and tb clear the cowl?
Old 09-17-2014, 05:05 PM
handyandy496's Avatar
Im thinking along the same lines intake wise. Should rev up high easily.
I'm curious as to what your cam spec's are?
Old 09-23-2014, 03:46 PM
BOLO's Avatar
Default Gld
We'll do PSJ! Aiming for Spring 2015
Old 09-23-2014, 03:50 PM
BOLO's Avatar
Yes it will require cutting the the cowl area all the way to the glass to clear this intake set up.
Cam specs will be posted as soon as I get the whole top end from Brian.
Quick Reply: 416 LS3 Build Underway (Pics inside)
