for sale 02 camaro built turbo 76kmiles !!!SOLD!!!
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $14000
Mileage: 75000
Location (State): CA
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
Hello I'm selling my camaro that I've had ownership of over 8 years and always been garage.
My reason for selling is I am to moving to Colorado offgrid.
More pictures in here
https://ls1tech.com/forums/appearanc...l#post16023562
I purchased this car December 21 2006 with 32k miles and for the first few years of ownership stayed relatively stock. few years ago i decided to turbo the car. I have put about 10K miles on the car since the build and most parts below only have that
she only has 75k miles on the body
MODS:
going off of memory i will list the mods but almost every part of the car that could be modded has been
ENGINE
-2006 4.8 pullout with appox 20k miles, this motor is gen4 base and has the improved connecting rods, they have proven with proper tuning they can handle over 800rwhp
- 317 heads to lower compression to 8to1 allowing for max boost, they have been ported and polished
- prc gold extreme valve spring
- ms3 cam
- 7.400 hardend pushrods
- arp 2000 rod bolts
- arp head studs
- ls9 headgaskets
- ported and polished edlebrock proflo intake
- rev extreme 95mm TB
- umi billit soild motor mounts
- lingfelter 2step control module
TURBO SYSTEM
- 76mm on3 turbo
- custom turbo kit built from thick wall tubing retains a/c and all accessories wrapped with titanium exhaust wrap
- titanium t4 turbo blanket
- synapse 60mm wastegate
- custom 4" down pipe with splitflow muffler with passenger side bumper exit exhaust with cutout
-custom 3" mandule bent exhaust to back of car with large quite MagnaFlow muffle very quite with cutout closed
- cx racing 4" core intercooler mounted at 45 degree angle to eliminate the need to cut open the bumper
- custom fitted 3" intercooler piping
- custom powersteering lines to avoid turbo hot parts
DRIVELINE
- stg 3 built t56 with billet keys,carbon blockers,all new bearings,heavyduty tailshaft busing
- mgw shifter, with custom shifter stick adapter and hurst stick and ball
- pst 3.5" aluminum driveshaft
-moser 9" with 4.11 gears, aluminum center section, trutrack posi, 31 spline axels and 3 channel abs, stock fbody length
SUSPENSION
- UMI kmember, front adjustable upper and lower tube a-arms
- edlebrock front ias coilovers with the upper mount mod for increased travel
- SS front sway bar
- UMI rear adjustable control arms and panhard bar
- UMI tunnel mounted tq arm
- Intrax rear springs and edlebrock ias shocks
- UMI weld in subframe connectors
BRAKES
- front gen1 ctsv 4 piston brembos
- front c6z06 rotors
- custom braided brake lines
- stock rear calipers that have been modded for use of drag wheels
WHEELS
- front and back oewheels c6z06 dd 18x10.5 black with polished lips
- nitto 295/35/18 nto5 front tires
- toyo 305/35/18 r888 rear tires
FUEL
- dual intake fuel pumps , walbro 255 main and aeremotive 340 comes on with boost
- aeremotive adjustable fpr and evap line has been converted to return to tank
- edelbrock fuel rails
- 80lbs fuel injectors
- custom street tune
EXTERIOR
- fiberglass "sunoco" hood
- 6LE carbon fiber targa top
- 6LE carbon fiber sail panel
- whistler headlights with 6500k 55w low beam hid and 5500k 55w highbeam hid with mod so lows beams stay on with high beams
- all badges are blacked out
- front turn signals blackout
- lt1 rear tailights
- Black PHK sticker
INTERIOR
-6LE seats mounted on factory power seat rails, rear seats have been deleted
- 4 point racing seatbelt harness
- grant steering wheel, with quick disconnect
-triple gaugepod with aem wideband ,glowshift watertemp and boost gauge
- 5% rear window tint, 15% front window tint .
- batter relocated to truck
I would rate the car as so
interior 9/10 inside is mostly perfect except a small tear in the carpet by gas peddle and a small crack in the driverside window switch panel
exterior 7/10 is mostly what you would expect from a 10 year old car, the paint is not perfect and being black shows every imperfection but nothing i think a good detail/polish job could clear right up. There is a couple small dings in the rear quarter panels, nothing anybody would see unless pointed out
motor/driveline 9/10 the car runs great, spools around 3500rpm depending on gear and redline at 7000rpm
The car has been my love, i have dumped so much money into it i have lost track but can say there's easily 20k in mods alone
Car currently has custom street tune and at 15psi makes 621hp
i have the car on criagslist for 16k I want 14kfirm. I am open to serious offers or possibly trades for rv, travel trailers, 4x4 and or diesels
I had the car here for sale once before a couple years ago and since ive spent a few thousand in upgrades
